Other BSOD help
Discussion in 'Hardware' started by happyhammer7, 17 Jul 2011.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    I have got a couple of BSOD lately and I cannot identify the problem. I have used bluescreen view to identify what could be causing this.
    It displays the following files are causing the issue -
    tcpip.sys
    ntoskrnl.exe
    Where do I go from here? I have installed no additional hardware or software.
  2. dazedandconfused
    dazedandconfused generic babble ->
    26 Jun 2009
    Dont know about the BSOD, but would be useful to list your system specs and any overclocks etc
    Alot of the time its an overclock or a failing piece of hardware thats the fault rather than an install.
  3. TheLegendJoe
    TheLegendJoe Syntax error
    28 Oct 2010
    Navigate to: C:\Windows\Minidump folder and try to see what application is causing the crash- Both seem to be related to a dody driver accessing the internet.
  4. happyhammer7
    19 Oct 2009
    How can you find out what application is causing it? the .dmp file is unreadable
  5. happyhammer7
    19 Oct 2009
    I used the verified tool to see if I could get it to bsod. It seemed that gigabytes dynamic energy tool was a dodgy driver and instantly caused a bsod. But I don't see how this could cause my original problem as it appeared to be network related.
    I have done various shutdowns and restarts and no more BSOD, but I am not convinced.
  6. happyhammer7
    19 Oct 2009
    Update
    Ran windows debugging tools and the BSOD is being caused by Lycosa.sys, which is related to my razer keyboard. I have fully uninstalled the driver using CCleaner and cleared the registry.
    I then reinstalled using the latest driver, ran verifier again and it crashed and Lycosa.sys once more. Could this be a possible hardware fault? I'm a bit lost as to what to do. Beginning to detest Razer's shabby products.
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Can you test with older drivers/ ones windows finds for the keyboard vs ones from the Razer website ( or viceversa )?
