BT Daily
Discussion in 'YoYoTech' started by Thermolance, 25 Sep 2013.
  1. Kevin@YoYoTech
    Kevin@YoYoTech What's a Dremel?
    19 Sep 2013
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    Just want to point out that although I haven't bought anything YET, I really like that you guys are doing this.
    Keep up the good work.
  3. Kevin@YoYoTech
    19 Sep 2013
    Hi Lance
    Thanks for the support! we want to continue giving good deals out to the community. In the future we will have even more exclusive deals for the bit-tech community! We love to hear your comments and feedback on how we can improve so drop some comments of what products you guys would like to be deals and we will take that on board.
  4. Kevin@YoYoTech
    19 Sep 2013
  5. Parge
    16 Jul 2010
    Ok guys! Constructive criticism time (I hope you don't mind):
    You want to know the problem you have at the moment? You have a shop full of stuff - but its all out of stock!
    If a customer goes to YYT to buy parts and find only 1 in 5 of what he wants is in stock, he's going to go elsewhere for the whole order. Not only that, but when he's next looking for parts, he's going to go elsewhere straight away without even trying YYT.
  6. The Bear
    The Bear What's a Dremel?
    19 Sep 2013
    Totally agree with you and currently awaiting deliveries to land hopefully by next week the situation will be different appreciate the honest feedback.
  7. Kevin@YoYoTech
    19 Sep 2013
  8. Kevin@YoYoTech
    19 Sep 2013
  9. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 14/10/2013
    For today's offer we have TP-LINK’s 3.75G HSUPA USB Adapter, the MA180 allows users to acquire 3G mobile broadband access simply by inserting a standard SIM card into the adapter and plugging it into their laptop or desktop computers. It supports the latest 3.75G HSUPA technology, which provides improved data transfer rates.
    Highlights:
    Up to 7.2Mbps download and 5.76Mbps upload (Network Type: WCDMA)
    Micro SD card slot for up to 32GB of optional storage
    Bundled utility provides quick & hassle-free installation
    Internal antenna, no batteries or cables required
    Fast USB 2.0 connection to notebook/desktop computers
    This is a great piece of kit so grab a bargain and SAVE £13 now! -Limited Stock-
    Use PROMO CODE: BTKC13 at checkout
    http://www.yoyotech.co.uk/tp-link-ma180-375g-hsupa-usb-adapter
  10. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 15/10/2013
    Hi Guys
    The offer we have today is the Arctic Cooling Freezer i30 CPU Cooler.
    The Freezer i30 is an enthusiast-grade CPU cooler for the latest Intel socket 2011, as well as socket 1155 and 1156. Patented technologies, direct touch heatpipes, precision machining, a fan vibration absorption and a brand new mounting system offers you plenty of overclocking headroom at a minimal noise level.
    SAVE £10 with this offer exclusive to Bit-Tech.
    http://www.yoyotech.co.uk/arctic-cooling-freezer-aco-ac-freezer-i30-i30-cpu-dt-4-heat-pipe-cooler-with-120mm-silent-fan-for-intel-socket-lga-201111551156
  11. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    CODE NOT WORKING for me:duh:
  12. Move Up!
    Move Up! What's a Dremel?
    20 Sep 2013
    Hi Penryn
    Thanks for the info
    All Sorted..
    Please try again, should be working fine
    Teelzebub likes this.
  13. Kevin@YoYoTech
    19 Sep 2013
    Bt Daily 16/10/2013
    Today's Offer is the Lian Li PC-80B Full Aluminium Case!
    AROMORSUIT PC-P80 has 2mm thick aluminum front panel with world first and only three 14cm fans in the front to intake cool air into the system.
    ARMORSUIT PC-P80 features a huge internal space, user can fit the large, most powerful hardware, it can accommodate 12" x 13" EATX dual processor server board, and still leave room for other hardware. It also features 10 PCI slots, to suit the most advance graphics systems, it can hous up-to four dual slot graphics cards, ARMORSUIT PC-P80 designed for today's and tomorrow latest hardware.
    There are twelve 5.25" slots in ARMORSUIT PC-P80. There are also two modularized HDD cages, which can hold three 3.5" HDD each. The user can adjust the position of the HDD cage to suit their need.
    These case are on special sale at YoYoTech! -WAS £259.99-SAVE £110-NOW £149.99
    Use PROMO CODE: btKC110 at checkout
    [​IMG][​IMG]
    http://www.yoyotech.co.uk/lian-li-aluminium-pc-p80b-alu-black-case
  14. Kevin@YoYoTech
    19 Sep 2013
    Today's offer is a triple set of of silver 13/10mm Compression fittings.
    High-grade rugged compression fitting with a cylindrical thread (G1 / 4 "). The hose is securely held by the union nut and immediately creates a safe seal. This system Ensures a perfect seal and maximum safety but can still be released with one hand
    At YoYoTech we have them at a special price of ONLY 99p each
    So if you're looking to build a new watercooling setup and you need some fittings, come and grab a bargain while you can!
    90deg and 45deg are alphacool branded.
    Use PROMO Code: BTkc99 at checkout
    [​IMG][​IMG]
    http://www.yoyotech.co.uk/alphacool-1310-compression-fitting-90deg-revolvable-g14-chrome-62367
    http://www.yoyotech.co.uk/watercooling-fitting-62361-1310mm-compression-fitting-45-revolvable-g14-long-version-chrome
    http://www.yoyotech.co.uk/compression-fitting-outer-thread-14-compact-62124-silver-nickel
  15. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 18/10/2013
    Today's Offer is the Asus F2A85-M PRO FM2 motherboard.
    Precise digital power control for APUs and superb graphics on the AMD A85X platform
    •Dual Intelligent Processors 2 with DIGI+ VRM
    •Direct Key - A Dedicated Button to Access the BIOS Directly
    •USB BIOS Flashback - Easy, worry-free USB BIOS Flashback with Hardware-based Design
    •Fan Xpert 2 – Optimizes the Speed of All Fans for the Ultimate Cool and Quiet!
    •USB Charger+ - 3X Faster Charging for All USB Portable Devices
    •USB 3.0 Boost - Faster USB 3.0 Transmission with UASP
    •Network iControl - Real-time Network Bandwidth Controls
    •Windows 8 Ready – Assured Compatibility
    SAVE £21-Only £79.99-Limited Stock
    Use PROMO code: BTkc21 at checkout
    http://www.yoyotech.co.uk/asus-f2a85-m-pro-amd-fmx-a85x-ddr3-matx
  16. cookie! nom nom
    cookie! nom nom Modder
    27 Apr 2012
    nothing for today? :(
  17. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 21/10/2013
    Today's offer is the Club 3D HD7950 3GB Graphics Card.
    Club 3D proudly presents the Club 3D Radeon™ HD 7950 royalKing graphics card. With PokerSeries Club 3D offers a new level of special gamecards that delivers the best performance, newest features and best coolers.
    Was £189.99-Save £30-Now Only £159.99
    Use PROMO Code: BTkc30 at checkout
    http://www.yoyotech.co.uk/hd7950-3gb-club-3d-royalking-880mhz-1792-cores-5000mhz-gddr5-28nm-gpu-dvi-d-dvi-i-hdmi-2x-mini-dp-pci-e-30-graphics-card-cgax-7957o2
  18. Kevin@YoYoTech
    19 Sep 2013
    Today's offer is the GTX660Ti 2GB Gigabyte OC Windforce 2X Graphics Card.
    • Powered by NVIDIA GeForce GTX 660 Ti GPU
    • Integrated with the first 2048MB GDDR5 memory and 192-bit memory interface
    • Features Dual link DVI-I/ DVI-D/ HDMI/ DisplayPort
    • Core Clock: Base / Boost clock:1032 / 1111 MHz
    • Support PCI Express 3.0 x16 bus interface
    • Support NVIDIA 3D Vision™ Surround and SLI technologies
    • Support NVIDIA® CUDA™ Technology
    • Support NVIDIA® PhysX™ Technology
    • Support NVIDIA® FXAA / TXAA Technology
    • Support NVIDIA® Adaptive Vertical Sync Technology
    • System power supply requirement: 450W
    Was £199.90-Save £30-Now Only £169.90
    Use PROMO Code: BTKC660ti at checkout
    http://www.yoyotech.co.uk/gigabyte-gvn66toc-2gd-graphics-card-gf-gtx-660-ti-2-gb-gddr5-pci-express-30-x16-2-x-dvi-hdmi-displayport-gv-n66toc-2gd-eu
  19. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 23/10/2013
    From now on we will be updating our offers in the OP and latest post so you don't have to flick through the pages now if you want to find the offer :)
    BT Daily 23/10/2013
    Today's offer is the Corsair Raptor K50 Gaming Keyboard with customizable colour backlighting!
    The Corsair Raptor K50 gaming keyboard combines great key feel, onboard macro storage, 100% anti-ghosting with full-key rollover on USB, and 16.8 million color customizable backlighting for a precision gaming tool that you can customize for your games, your tactics, and your style.
    SAVE £5-NOW £63.99-Use Promo Code: BTKCK50
    http://www.yoyotech.co.uk/corsair-raptor-k50-gaming-keyboard-customizable-colour-backlighting
  20. Kevin@YoYoTech
    19 Sep 2013
    BT Daily 24/10/2013
    Today's Offer is the ASUS GTX770 Direct CUII Overclocked Graphics Card!
    The ASUS GTX770-DC2OC-2GD5 is overclocked, 20% cooler and 3 times quieter. This graphics card not only brings performance and features of the industry-leading Kepler architecture, but also incorporates a number of exclusive innovations and technologies. DIGI+ VRM with Super Alloy Power, an acclaimed design proven by a series of ASUS motherboards, delivers better power efficiency, lower noise and greater voltage modulation range.
    SAVE £20-NOW £299.99
    Use Promo Code btKC770 at checkout to claim discount
    http://www.yoyotech.co.uk/2gb-asus-gtx-770-directcu-ii-oc-28nm-pcie-30-7010mhz-gddr5-gpu-1058mhz-boost-1110mhz-cores-1536-dportdvihdmi-gtx770-dc2oc-2gd6
