Networks BT Family Protection and NetProtect Plus
Discussion in 'Tech Support' started by sourdough, 7 Aug 2013.
  1. sourdough
    sourdough Minimodder
    17 Sep 2010
    I am seriously thinking about ditching Virgin and go with BT given that I will be paying the same amount of money with added footie games with BT. What I would like to know is are these protection software a compulsory install as it says it comes free with the Broadband? If it is, can I uninstall them afterwards after the installation man has gone?
  2. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    Not compulsary at all. You don't have to install them, the engineer will just come and test your connection and ensure your pc can access bbc.co.uk or google.com and then run a speed check on speedtest.net.
    It's up to you if you install the Software. Though i think you have to sign up to get the license and software anyway.
  3. sourdough
    17 Sep 2010
    ah, ok, that's for explaining, now the only sticking point are the one-off charges which amounts to 85.95:)
  4. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Just switched from virgin to bt. Software is all optional (as is all the virgin stuff on your current account)
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    whatever you do, don't install the piece of **** software that may come with the new router.
