Windows Budget rebuild - Vista not detecting mouse or keyboard when installing
Discussion in 'Tech Support' started by spt, 8 Aug 2012.
  1. spt
    spt What's a Dremel?
    19 May 2009
    Finally got around to fixing my pc (wife threatening to remove it from the living room to make space for baby things). All going well until i get to installing vista. Mouse and keyboard working fine in BIOS but when i get to the install screen for vista to simply pick language time etc neither work.
    Help! The wife threat is looming over me!!!
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    USB K/B & Mouse?
    Can you try the an old school beyboard with a PS/2 connector if your motherboard supprots it?
  3. Deders
    Deders Modder
    14 Nov 2010
    What motherboard are you using?
    are the USB keyboard and mouse settings enabled in the bios?
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    you have to wait for windows to find usb k/boards and mice, ps2 ones work out the box
  5. kol
    kol What's a Dremel?
    31 May 2011
    Really? My mx518 is connected through usb and works fine through the windows installation.
    Sent from my Galaxy Nexus using Tapatalk 2
  6. RichCreedy
    24 Apr 2009
    it seems to vary from machine to machine, i think it depends on the usb controller on the board, some work straight away, some take a while
  7. kol
    31 May 2011
    Could be, my mouse is slow of the slowest once i setup the drivers but during windows install its really fast.
    + keyboard should work surely, as they never need a driver.
  8. spt
    19 May 2009
    Thanks folks will hunt down an old keyboard today.
  9. spt
    19 May 2009
    Managed to get vista installed using an old school keyboard. still no usb mouse keyboard functionality.
    Motherboard is gigabyte Z77X-D3H
    Processor I5 3550
    8gig RAM
    128 SSD HD
    Any ideas? Wife is openly mocking me!
  10. spt
    19 May 2009
    Sorted. had them plugged into usb 3 slots.
  11. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    you silly spanner, I'm surprised you had the balls to post that. lol!
    Good luck with the rest!
