Watercooling Budget Watercooling
Discussion in 'Hardware' started by chap, 9 Sep 2011.
  1. chap
    chap What's a Dremel?
    4 Jun 2011
    This watercooling kit is getting sold on ebay for only 59.99 pounds excluding shipping http://tinyurl.com/Magicool108
    This is an incredible price, is it good for watercooling or is it later on going to be a problem?
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    You would only be able to cool the CPU (thin 120mm rad) so you may as well go for one of the corsair AIO units (h50/60). It would give same cooling for a lot less hassle :)
  3. chap
    4 Jun 2011
    I like open watercooling that has access to the coolant including viewing so Corsair closed is not good.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    You'll probably get better performance and support from one of the Corsair units too.
    FYI there is no 'budget' watercooling, only expensive and less expensive :p
  5. fdbh96
    29 May 2011
    But the fan Inc. Will be awful and the pump will be loud. I don't know this but for £60 its very probable ;)
