Buggered 800 Duron ?
Discussion in 'General' started by Forsaken, 17 Apr 2001.
  1. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Got an 800 duron here that wont even hit 800 (dont get into windows), was running fine at 800, but after a lockup in windows it decided not to work at 800 again.
    But it will run at 103*7.5
    Then after another crash / lockup, it seemed to only like the idea of working at 100*7.5
    CPU Temp 28c
    System Temp 23c
    (taken from VIA Hardware Monitor v2.04)
    CPU Voltage set to 1.85v
    I/O Votlage set to 3.50v
    Fop 32-1
    6*80mm evercool fans for case cooling
    Herc GF2 mx
    128mb Cas-2 pc133 ram
    Abit KT7a Raid
    Any ideas lads ?
    Ta,
    Fors
  2. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Clear your CMOS and try again that may help.
    Or you could try removing PCI/ISA cards until you find out if one of them is making the system crash.
    James
  3. Ataraxia
    Ataraxia <b>OOH BABY!!!</b>
    12 Mar 2001
    sounds duff to me :(
    my mate's just got a duron 800 (like, put it together at 8pm yesterday), not had chance to test it yet. i'll tell you how that fares, he's got a kt7a and it shows 41deg cpu in the bios. (super orb) but no case fans... yet muahahaahaha... 6 80mm's gettin whacked in v.soon
    [Edited by Ataraxia on 17-04-2001 at 10:33 AM]
  4. Forsaken
    27 Mar 2001
    Just cleared the CMOS, reseated all me cards, memory, still nothing.
    it worth doing a fresh reinstall or does anyone have any other ideas.
    Thanx for the ideas neways.
    I'll be a bit pissed if the CPU is buggered, seems strange that it used to hit 1Ghz before.
