Notebooks build a laptop?
Discussion in 'Hardware' started by spectre456, 6 Jul 2008.
  1. spectre456
    spectre456 What's a Dremel?
    29 Dec 2007
    i was wondering if i coud get some guidance on this. my aunt asked if i could build her a laptop since i just recently build a great gaming machine. her needs are rather modest:
    internet browsing
    word processing
    the occasional movie (integrated graphics should do, right?)
    i also think she wants to run vista, but i'll probaly put xp on since it runs smoother. vista capable will just be an upgrade option
    im completely new to this and would like to know if its even possible to build this and where i can get the parts. (i hear some sites sell chassis but not openly).
    her budget is about £400-£500 if possible and i'd like to make it slightly future proof for her eg. extra ram slots.
    any help would be appreciated thanks :thumb:
  2. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    home building a laptop isn't as easy as a desktop and for £400-500 you should be able to get a pretty good core 2 duo laptop with 3GB of ram and a decent sized hard disc. The one thing missing from your spec is the monitor size which will dictate the price of similar specced machines, which also goes hand in hand with the weight etc.
  3. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    the best you can do is buy a barebones laptop (everything except hard drive, ram, expansion cards, etc.) and install the stuff yourself.
    do the math first though, it might be better to just buy a Dell with ubuntu installed on it.
    (because seriously, ubuntu is fun)
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Just get a Dell...
  5. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    laptops sell in such bulk these days that big shops make a (relatively) small profit per unit sold so building one is, well there isn't much point to be honest. If you do want to though, the barebones idea is pretty good. But really, keep an eye on the money going into it.
  6. DougEdey
    5 Jul 2005
    You can get a Core Duo (t7something) for £375 from Dell with 2GB/120GB X3100 graphics. No need to build your own
  7. spectre456
    29 Dec 2007
    thanks for the replies, it seems more feasible to just buy one it seems. there isnt much of a margin for saving money as there is for a desktop build. maybe if/when i build a gaming laptop is might be worth it. that dell doug mentioned seems like a good buy. i'll talk my aunt into buying one instead of making me work:D.
    once again, thanks for the replies:thumb:
  8. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    The problem with trying to build a laptop from "scratch" is that there is a limit to how customizable it can be. More and more components get soldered on the motherboard, so basically the only thing you can choose is WLAN cards (Basically Broadcom or intel...), memory and CPU. GPUs are normally soldered on, and on smaller laptops even the CPU are soldered on.
    As others have said, there is nothing to save on trying to put it together yourself.
  9. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Expensive... unless of course you use a briefcase and desktop PC components, but that last time I did that it didn't work out as well as I'd hoped:p
    There are some good examples of it though on here:) if you look up Briefcase PCs it works just as well, but if it's for your gran it might be a bit heavy to carry the entire thing around
  10. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    yeh,just buy a new one. cheaper and easier. the point of self built machines is price and hardware flexibility. all you're asking for here is something that will play movies...i mean heck just buy a eeepc and an external monitor! it'll still work out cheaper! hehe
