Cooling Build help needed
Discussion in 'Tech Support' started by hirezo, 1 Oct 2010.
  1. hirezo
    hirezo Minimodder
    27 Jul 2009
    i need help with a build, i put together my friends rig today and everything went through ok, the only problem i had was after it turned on it said that the CPU temperature was too high, im sure i put on enough thermal paste and im sure i didnt put too much. how and what can i do to fix this issue?
    btw, the cpu, hsf and motherboard are as follows:
    AMD athlon phenomII x2 555 3.2ghz black edition
    artic cooling:freezer pro 7 rev 2
    asus m4a785td-v evo
    thanks in advance
    -Rezo
  2. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    check to see if hsf is installed properly and making full contact with cpu. Take hsf off the cpu and verify that you did not use too much TIM and that it's spread evenly on the cpu. Check fan speed on the HSF.
    What case? Good airflow coming in? If there is bad ariflow coming in, the fan will just push warm air through the HS and won't do much good.
  3. hirezo
    hirezo Minimodder
    27 Jul 2009
    thanks seb, the hsf is definitely working as its pulling the air through and i feel the metal grills heating up. the case isnt a high end one, its made by a company called casecom. i think the issue is with the thermal paste. we used the paste that came with the fan, i think it was called antec formula which i believe to be the problem, do you think if i get artic silver it will resolve this problem?
    thanks again.
  4. nightblade628
    nightblade628 Minimodder
    10 Dec 2009
    It shouldn't, as the stuff that comes with it is usually good enough NOT to overheat the CPU. Regardless, I'd recommend getting some Arctic Silver and reapplying it; it's better quality and the reapplication should ensure it's all done properly.
  5. bulldogjeff
    2 Mar 2010
    The Antec stuff ok, I've used it and had no problems with it. What temps are you getting? When applying the TIM a blob the size of a small pea is plenty and then spread evenly, also make sure when you tighten down the cooler , do i in stages on opposite sides rather than just cranking down each corner so it goes down nice and evenly.
  6. seanbean
    seanbean Certa Cito
    21 Apr 2010
    Max Temp. 70o Celsius. Nominal Voltage. 0.850-1.425V. Max TDP. 80 Watts .
  7. hirezo
    hirezo Minimodder
    27 Jul 2009
    hey guys, the temperature reading in the bios was 127oC.
    We went into the YoYoTek today and they seem to believe that it might actually be the that the hsf is not touching the cpu properly, so tonight we're gonna apply artic silver 5 and also try out the stock fan.
    fingers crossed!
  8. Golygus
    Golygus Minimodder
    9 Oct 2003
    Does sound like the hsf isn't fitted properly.
    The heatsink came with Artic cooling's MX-2 compound pre applied - this shouldn't have been touched!
    MX2 is better (MX-3 better still) than Arctic silver 5 (or 3) which is in turn much better than the 99p sachets of junk.
    Bit-Tech's How to apply TIM
    Make sure the AMD lugs are attached to the cooler properly as describe in the install manual on Arctic's website.
  9. hirezo
    hirezo Minimodder
    27 Jul 2009
    oh crap lol, i didnt know that...i always rub off the stuff that comes pre-applied thinking its just generic thermal compound :S.
    however, we applied arctic silver 5 and on the stock fan and had the same issues....am i wrong thinking the problem is the cpu itself??
  10. Golygus
    Golygus Minimodder
    9 Oct 2003
    can you take a photo of the hsf in situe? in detail the retention clips?
    Its unlikely to be the CPU.
