Scratch Build – In Progress [BUILD LOG] Project Ametros: Scratch Built Carbon Fiber Case + WC - Mar 11, 2012
Discussion in 'Project Logs' started by motorsportcfd, 25 Jan 2012.
  1. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Ugh why cant you delete posts?
  2. peteski
    peteski long live the pc
    8 Jun 2011
    that carbon shell looks amazing i cant wait to see some comonenets in there :rock: :rock: :rock:
  3. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Awesome update! Did you pull out the balsa core on the pedestal?
  4. motorsportcfd
    motorsportcfd What's a Dremel?
    25 Jan 2012
    I noticed that same thing. When I get the reservoir built I'll take pics in my studio under controlled lighting to help achieve the actual appearance.
    Not sure, but I appreciate you inflating my reply count of the thread! :rock:
    Thank you man!
    Thanks for the motivation! I left the balsa core in there for strength, just like the chassis. it adds a lot of rigidity to it, plus its lightweight! Not that it matters since the HDD's, watercooling, TEC chiller, and PSU's will make the thing weigh a few dozen kilos. :lol:
  5. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    I've been meaning to ask you what program you run your CFD with? SolidWorks, COMSOL, Ansys, etc.? Also, your CAD?
    Love the pictures...and the mouse!!!
  6. Luke@90
    Luke@90 What's a Dremel?
    26 Feb 2012
    amazing carbon job and polishing!!! can't wait to see next up
  7. motorsportcfd
    25 Jan 2012
    Thank you. I use SolidWorks 2011/2012 for the CAD work. For the CFD/FEA I use an Ansys extension package for SolidWorks. On the rare occasion I'll use OpenFOAM. But I prefer the Ansys FEA/CFD Engine withe SolidWorks extension as it's all in one.
    One of these days I would like to use STAR-CCM+
    Thank you for your compliments. Working on the reservoir right now!
  8. motorsportcfd
    25 Jan 2012
    I'd like some advice from some of the more experienced guys out there. There's a lot going on in my loops, three loops to be exact.
    Loop 1: Res --> 2x DDC-1T Pumps --> TEC Chiller --> CPU & MOBO --> Res
    Loop 2: Res --> 2x DDC-1T Pumps --> Rad --> GPU's --> Res
    Loop 3: 2x DDC-1T Pumps --> TEC's --> Radiator
    Loop 3 will be cooling six TEC's/1000watts.
    I am open to thoughts and suggestions.
  9. Cheapskate
    13 May 2007
    It doesn't matter much cooling-wise, but most here would prefer the pump directly before the cpu block.
    Nice rig, and congrats on MOTM nomination.:D
  10. Furball Zen
    25 Jan 2012
    I went pump->rad->CPU in my old, its said this takes any heat the pump adds out. Not sure how i will do this in my new one.
  11. Cleveland216
    30 Dec 2007
    You got my vote from MOTM, keep up the good work!
  12. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Don't you dare do a Langer on us! I will fly to the states and skull f**k you if you do a Langer on us.
    I am addicted to this log!
  13. motorsportcfd
    25 Jan 2012
    11.0 Gluing the Reservoir Together
    Sorry for the long pause between updates. I'm in the middle of starting a new job, so things have been pretty crazy lately. I started gluing together the reservoir now that all the pieces are made, and the the fusion rods are almost done. The fusion rods just need to be cut to size and finished up. I'm really happy with the way the reservoir is turning out.
  14. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    You had to bring that name up; didn't you? I still have dreams that one day Helios and/or P-Cu will be finished... :( Oh well.
    PS: That res looks sick. And as far as loop order goes; only thing that really matters is that pumps are after res so that they're never starved for water.
  15. peteski
    8 Jun 2011
    mate thats one sick looking res cant wait to see it in the case :rock: :rock: :rock:
  16. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Am I reading this right that you are planning on using 6 DDC pumps? What in the world for? I don't see the need for that kind of pressure at all. Also, why are you splitting the flow in loop 1 between the CPU and MOBO? Unless you can balance out the restriction in two sides of a parallel loop, you are going to be better off going in series with this. Also, in loop 3, you are going to have a very difficult time getting water into the inlet of that pump with it up higher than the rad like that. Also, how are you going to fill/bleed that loop? You at least need a T-line or something before the pump inlet.
  17. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Oh, missed this one... you are GOOOOD!
  18. amagriva
    amagriva Minimodder
    13 Jun 2009
  19. motorsportcfd
    25 Jan 2012
    Not six pumps in series; two pumps per loop. After doing some CFD analysis, running two DDC pumps in series has a better flow through the waterblocks due to the high head pressure. I'm still doing some transient thermal analysis to determine an exact flow rate for best cooling efficiency. However, from preliminary studies, dual pumps in series has proven to be the most optimal solution.
    Six pumps in series is overkill, even for me.
    I will do that. Thanks! :thumb:
    There will be fill/bleeds, I just haven't drawn them into the diagram.
  20. Cleveland216
    30 Dec 2007
    Those are great pics! Come on show us the build process...i want to see how you put those together.
