Modding Building a case
Discussion in 'Modding' started by apl1970, 10 Dec 2004.
  1. apl1970
    apl1970 What's a Dremel?
    4 Dec 2004
    O.K., here we go.
    I`m, too say the least, a little disapointed with the range of cases available in todays market, they don`t come near my needs :(
    I`ve got the standard gear, 2 optical drives, 2 hd`s etc, and I also have a custom bought water cooling system (Thermochill 120.3 rad, Eheim 1250) but can`t find a case to fit it all in!
    What I`d really like is a double (or close to it) case without any fan holes pre-drilled.
    I was going to build my own from Perspex and alluminium `L` section (12mm) but would rather buy one / get one built for me.
    Does anybody know where I can get a case or get one made? Preferably in the U.K.
  2. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    I dont think theres anywhere in the uk that will make a case from scratch for you, its a pretty specialised area your best bet is to make your own at least then you have the satisfaction that you built it yourself.
  3. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    i could build 1 out of steel or possibly aluminum with plexiglass sides,top,bottom,back and front but i live in the use :-\
  4. richard-wong
    richard-wong What's a Dremel?
    6 Aug 2004
    aluminium L section is great ideal with rivots! fantastic. my university has all of that at my disposal even large quantity of aluminium sheets!
    wkd
    might build a case for my self :)
