BUilding a computer to play Half life 2...
Discussion in 'Hardware' started by Stew, 14 Dec 2004.
  1. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    I already have a Hard drive, psu and case and dvd drives, but am totally out of it as to what hardwear (mobo, cpu, ram GFX card) I would need to run it. I'm talking real bang for buck performance here.
    ANyone got any suggestions?
    Cheers :thumb:
  2. alastor
    alastor Minimodder
    6 Sep 2004
    What sort of budget you got for it?
  3. Stew
    6 Mar 2002
    lets say £400, although I dunno if thats enough for something decent....
    thats for mobo, cpu, ram + gfx
  4. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    It's possible to squeeze a s754 into that price easily, if that's good enough for you. Probably with a decent Sempron, 6600GT and 512mb of ram, pushing for 1gb
    <A88>
  5. <A88>
    10 Jan 2004
    Okay here are the prices according to ebuyer
    -6600GT:£145
    -Gigabyte NF3 Mobo:£63
    -s754 Sempron 3100+:£79
    -1GB DDR400 Corsair Value Select Memory:£105
    Total >>£392<<
    Hope this helps!!!
    <A88>
  6. Stew
    6 Mar 2002
    I pleased you posted that I was wondering what the hell an sempron was.
    Great stuff I'll go tell my mate the prices
    Cheers :thumb:
  7. kergareth
    kergareth Minimodder
    6 Jul 2004
    sry, alex has better suggestions. (Was doing price research while he posted)
  8. blah
    blah Minimodder
    16 Jul 2004
    Are you taking the ***** a 5200? DO NOT BUY THIS CARD!!!!
  9. Stew
    6 Mar 2002
    just to throw a spanner in, what sort of ATI card would fit the bill?
    not a great fan of geforces anymore
  10. herbs
    herbs Nobody but us chickens
    7 May 2001
    The x700 would be the competing ATi card.
  11. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    x700 pro then?
    ranging 120-140
    i think it should be capable of HL2 medium settings
  12. <A88>
    10 Jan 2004
    wtf? :confused:
    <A88>
  13. blah
    blah Minimodder
    16 Jul 2004
    the X700 should be able to play it nearly at top everything, the X700 is better than my 9800Pro and mine runs fine on everything full at 4 x AA and 2 x AF or something. I was just saying don't buy the FX5200, not being rude but it is a really bad idea. Buy a 9800 Pro second hand or a new 6600GT.
  14. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    my 9600 pro runs HL2 fine on all high settings at 1024x768, with 2x AA.
  15. <A88>
    10 Jan 2004
    Oh right...but did anyone actually suggest a 5200?
    <A88>
  16. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    nope. and isnt the x700 pci-e?
  17. webbyman
    webbyman Hax.
    7 Oct 2004
    you should get an
    amd 64 3000+ s939 cpu £100
    s939 nforce 3 ultra mobo £80-90
    6600GT graphics card £120
    good dual channel 2x256 ram or 1 gb of ok ram £80-110
    about £400 :thumb:
  18. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I saw a benchmark that showed the 9800Pro/XT versus the 6600GT in HL2. IIRC the 9800Pro came out on top, so if the system's purely being built for HL2, then the 9800 would be a better bet, and it's cheaper :)
  19. blah
    blah Minimodder
    16 Jul 2004
    He has edited his post which said a FX5200:
    kergareth
    Multimodder
    __________________
    Due to budget cutbacks the light at the end of the tunnel will now be extinguished.
  20. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Id definitely reccomend a 9800 pro over a 6600 if your primary objective is Half Life 2.
    My reccomendation on hardware is an Athlon 64 2800+ or 3000+ (socket 754), Nforce 3 motherboard, 9800 pro, and 512 MB to 1 Gigabyte of RAM.
