Modding Building my own case question
Discussion in 'Modding' started by TurtlePerson2, 11 Feb 2008.
  1. TurtlePerson2
    TurtlePerson2 What's a Dremel?
    19 Dec 2006
    I would like to build my own custom computer case. I have experience with and access to a metal shop, so getting tools like drill presses and band saws isn't the difficulty. The problem is that I'm having a hard time finding the official ATX specifications for a case. I tried formfactors.org, but had no luck. Does anyone know of a good site with either plans or a list of specifications for an ATX computer case?
  2. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Can't you just look at pictures of cases and base yours off of those? I think that ATX case spec is listed partially in the motherboard specification [for clearance over parts of the board]. The most important part I think is the front-->back airflow design, which some manufacturers are throwing out the window anyways.
  3. radodrill
    radodrill Resident EI
    14 Mar 2006
  4. aaronpoweruser
    aaronpoweruser new mod coming
    25 Jun 2008
    just get a cheap case of ebay and somthing and mount the mother board tray
  5. jhanlon303
    7 Sep 2006
    Garage sales, thrift stores, carity sores, flea markets all ha cheap finds.
    John
