Other Building new budget PC? Comments please
Discussion in 'Hardware' started by jakespp, 28 Dec 2010.
  1. jakespp
    jakespp What's a Dremel?
    28 Dec 2010
    These are the components:
    http://www.ebuyer.com/product/235421
    http://www.ebuyer.com/product/220150
    http://www.ebuyer.com/product/240998
    http://www.ebuyer.com/product/173122
    http://www.ebuyer.com/product/176026
    http://www.novatech.co.uk/novatech/prods/components/cases/cases/Novatech/NOV-PANTHER.html
    http://www.ebuyer.com/product/155641
    http://www.ebuyer.com/product/124735
    I'm not looking to do intense gaming right now, but I want to chose components that will give me a chance to upgrade later down the line. Do all the components work together, I have checked and the only thing I'm unsure of is the RAM compatibility. Thanks
  2. Guest-16
    Guest-16 Guest
  3. Uxon
    Uxon Minimodder
    14 Dec 2010
    I think with his budget he won't be able to afford a SB build so might as well ignore that option.
    I'd suggest changing to this HDD:
    Samsung F3 500GB
    Also if you can afford it, switch the case+psu you've suggested for this combo:
    Coolermaster 430 + 500W psu
    Shouldn't add too much to the total price. :)
  4. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    To save everyone a headache here is a list of his current choices:
    Processor: AND Athlon II x3 455 (3.1Ghz)
    Motherboard: Asus M4A88T-M 880G Socket AM3
    RAM: Corsair 4GB (2x2) DDR3
    Hard Disk Drive: WD 320GB Caviar Blue
    Case: Nova Panther
    Powersupply: Corsair 430w CX PSU
    Optical Drive: LiteON 24x DVD±RW
    Wireless Adapter: Tenda Wireless N300 PCI
    Adapter
    Hope this helps people
    My recommendations is a better case (antec 300?), a different hard drive (samsung F3?) and power supply, you could drop down the cpu to an AMD Athlon 250 dependant on if you really need a third core?
    Publ!c Enemy likes this.
  5. Greentrident
    Greentrident Minimodder
    10 Jul 2009
    I think the case looks OK - if you were going to spend extra I'd get a bigger hard drive - I'd go with 1TB if possible - the samsung F3 is excellent.
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I'd drop the case and go with a Cooler Master Elite 335 or 430.
    Also, for the same money you could have a Wester Digital 500GB Caviar Blue.
    Change the LiteON to a Samsung SH223
    Teelzebub likes this.
  7. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Do you have an OS you can use?
    also what is your budget dude?
