Build Advice Building new PC
Discussion in 'Hardware' started by cc3d, 26 Jun 2021.
  1. cc3d
    cc3d It's a mod mod world
    14 Jan 2008
    First time building a PC in 5 years. Haven't really kept up with specs lately.
    My current rig:
    Processor Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz 3.60 GHz
    Installed RAM 32.0 GB Corsair XMS3 32GB (4x8GB) DDR3 1600 MHz (PC3 12800)
    EVGA GTX 1070
    EVGA GTX 960
    ~6 TB of storage
    Boot drive is samsung 500 Gb SSD
    4 SSDs
    2 spinning drives
    Dell P2715Q Monitor
    Dell U2913WM Monitor
    I'd like to build today's equivalent and use my current graphics cards until I can find/buy a new card at MSRP. I have case and power supply to use and a few extra SSD's.
    So I am need recommendations for:
    Motherboard
    CPU
    RAM
    I tend to like to EVGA, ASUS and Intel
    My budget is around $800-$1000, would like to spend less. Not looking to break records, but would like o build something expandable.
    My primary activities are graphics, 3D modeling and gaming. Note that my current rig does pretty well with these now, but I am ready to grow.
    TIA
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What speed is your RAM? As you can probably reuse that.
  3. cc3d
    14 Jan 2008
    Corsair XMS3 32GB (4x8GB) DDR3 1600 MHz (PC3 12800) Desktop Memory 1.5V
  4. Bloody_Pete
    11 Aug 2008
    Ah, yeah you'll be wanting more like 3200MHz or 3600MHz these days! TBH you'll probably get most benifit from a Ryzen 5xxx CPU and a x570 board. And of the Asus ones are good, and ones without the chipset fan are just releasing.
    Something along these lines https://pcpartpicker.com/list/YDTMkX That CPU can be a bit tricky to find but I think its getting better. It doesn't come with a cooler, but you didn't specify what you currently have.
  5. cc3d
    14 Jan 2008
    I appreciate your assistance. I am still a little reluctant to jump on the AMD processor. Will that AMD do as well or better than the Intel i7 for gaming, rendering?
    This is where I am now (if I stick to intel)
    • ASUS Prime Z590-P LGA 1200 (Intel 11th/10th Gen) ATX Motherboard
    • G.Skill RipJaws V Series 64GB (2 x 32GB) 288-Pin SDRAM DDR4 3600 (PC4-28800) CL18-22-22-42 1.35V Dual Channel Desktop Memory
    • Intel Core i7-10700K Desktop Processor 8 Cores up to 5.1 GHz Unlocked LGA1200 (Intel 400 Series Chipset) 125W (BX8070110700K)
    Another question: Are AMD video cards easier to get than NVidia? I really doubt I'd go to AMD on graphics cards, but want to know.
    TIA
  6. Bloody_Pete
    11 Aug 2008
  7. cc3d
    14 Jan 2008
    Thanks for that! I may just go AMD this time. Obviously more expensive, but appears to be the bigger bang for the buck.
    Bloody_Pete likes this.
