Scratch Build – In Progress (Buildlog: custom case) Building the beast!
Discussion in 'Project Logs' started by z3bb0, 30 Jan 2012.
  1. z3bb0
    z3bb0 New Member
    3 Dec 2011
    So I wanted a case that could aircool and watercool so I spent some time designing my own case using sketchup and ended up with this (changed from inverted to norml mobo tray later on) : [​IMG]
    wont be using that crazy hardware but still :D
    this is what what I'll be using to build the frame, with a ATX psu for reference
    metal in da hause?
    done! :D
    picked up 2 180mm fans from silverstone, airpenetrator ones
    really big as you can see, the case in the background is a Fractal design R3
    built in fancontroller for 2 fans I think? awesome
    This is how there going to sit in the case, tall? oh yezz
    how they look next to the frame
    found this old harddrive cage and modded it to fit 2 hdds, might use it.
    got the plate to hold the 2 180s in the front in :D
    pretty big huh?
    I/O shield, on/off button, dust filters and some fan grills :D
    the beginning of a 5.25 bay :D
    how I'm going to fit the I/O shield and back fan
    still room for a mid plate
    and plenty of room for a 120mm fan
    3.5cm of cable management room behind the mobo tray
    can go for 2 120mm fans but not sure if I actually want to
    9cm of room for fan and rad :D
    picked up some mesh, alot actually
    custom fan grills anyone?
    looks pretty beast
    I/O shield mounted and back 120 is mounted
    outside view, ignore the scratches :duh:
    back with fan mounted
    outside view with fan, looks okay?
    3 5.25 D-drives mounted
    carbon fiber !!! cheap stuff though :/
    wont be running out of this for awhile
    Had to try it out some :) Looks okay?? :worried:
  2. peteski
    peteski long live the pc
    8 Jun 2011
    looking sweet mate keep up the good work :rock: :rock: :rock:
  3. z3bb0
    z3bb0 New Member
    3 Dec 2011
    thanks :), my only reply :(
    Update
    Start of a new rad holder for the top :D
    done
    mounted and fans fitted
    got a handle for the back 120fan grill and a 30CM ruler for reference
    here's the dust filter mounted on the 180 airpenetrator fan
    180s mounted in the case
    the piece of paper is 17x17cm which is about the size of an mini-itx motherboard. So I could get 2 systems in there :D
    the cpu power for the top of the motherboard is no where as long as it needs to be, sure this psu has an extra short cable but still I'll be needing some extensions
    that's all for now :roll: Hoping to get the motherboard tray in soon..
  4. z3bb0
    z3bb0 New Member
    3 Dec 2011
    some pics of the rig that's going to be installed in the case :D
    tried to take some pics of the gpus but I don't really know how to use this camera but I'll figure it out soon :)
  5. peteski
    8 Jun 2011
    pics of the gpu look good mate :rock: :rock: :rock:
  6. z3bb0
    z3bb0 New Member
    3 Dec 2011
    Thanks man :) I'll be taking some pics with the camera when I changed the lens and maybe I'll be able to focus on the card instead of the background :D Thanks for commenting :)
  7. Bladesingerz
    Bladesingerz Member
    30 Nov 2011
    Nice stuff so far! Good luck on soldering extensions on that PSU, its a pain!
  8. z3bb0
    z3bb0 New Member
    3 Dec 2011
    No I'm just using this psu as a try out :) I'll be using my TX850 from corsair
  9. z3bb0
    z3bb0 New Member
    3 Dec 2011
    Yay, I got the motherboard mounted and it sits there good.
    Case with the motherboard in.
    from behind
    2 L brackets to secure it
    2cm cable management space under the bar, 3.5cm elsewhere.
    also changed the PSU mount to be able to mount the psu with the fan down
    nearly 5cm of breathingroom
    That's all for now :)
  10. monkiboi
    monkiboi Member
    5 Feb 2012
    What's the proper name for those corner connectors so I can find some. I presume by the following pics the tubular bars slide or fix on to them somehow?
  11. z3bb0
    z3bb0 New Member
    3 Dec 2011
    I have no clue what they're called in english :/ but you slide them in using some force :p using a hammer and they sit firm...
  12. dwinsor
    dwinsor New Member
    9 Jan 2012
    Can i ask where you got them from have been looking to do the same with a case design.:thumb:
  13. Metrodusa
    Metrodusa New Member
    14 Jan 2012
    Nice mod and nice idea using the 3-way connectors for the corners. Looking forward to seeing more updates.
  14. z3bb0
    z3bb0 New Member
    3 Dec 2011
    Bauhaus, it's a swedish store btw..
  15. peteski
    8 Jun 2011
    coming along nicely mate keep up the good work :rock: :rock: :rock:
  16. z3bb0
    z3bb0 New Member
    3 Dec 2011
    Thanks mate :)
  17. z3bb0
    z3bb0 New Member
    3 Dec 2011
    quick update
    one sidepanel done and the roof is soon done + midplate :p
    that's all for now
