Buying a New case
Discussion in 'Hardware' started by Bust_A_Cap, 12 Jan 2006.
  1. Bust_A_Cap
    Bust_A_Cap What's a Dremel?
    22 Dec 2003
    Aight so i'm about to graduate and i'm looking at building just one bad ass case before i do. So i've decided that the first thing i will do is try and track down a bad ass case. What i'm looking for is a spacey mid tower...but really plain. Preferably no fan holes in front or side. Also i want it to be just straight edge, like no curvy designs and all that ****...and prefeably to have a metal face plate...i might end up making one but does anyone have any ideas on what kind of case would meet some of these requirements...thanks!
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    Coolermaster Centurion 5 :thumb:
    It has an 80mm fan at the front and a fan mount on the side but other than that it's a great case.
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    lian li's are about the closest things ive seen to totally plain. At least the older models.
  4. Krikkit
    21 Jan 2003
    Try Cheiftech BX's - a very plain and cheap tower (compared to LiLi's and CM's anyway) to mod. :D
    Plus you can buy yourself a new front panel if you fudge it.
  5. Pookeyhead
    30 Jan 2004
    It's purely subjective. Some like Lian Li, some like Coolermaster... both are excellent. Go with whichever you think looks coolest, and whichever fits your requirememts - such as space, drive bays, fan size etc. Both Coolermaster and Lian Li will make something that fits your needs, and both will be of superb build quality.
  6. Bust_A_Cap
    22 Dec 2003
    I REALLY like the look of that coolermaster case...it is a little spendy but i don't know, i'm not a big fan of the front door deal...but i also like the front intake and rear exhaust, right now my current computer overheats quite regularly so i'm begining to understand the point of cooling hahah. Does anyone know of anyone else that makes a case similar to the Coolermaster Centurion 5 but is cheaper?
    Thanks!
  7. 5aboy
    5aboy Minimodder
    5 Oct 2004
    try the antec p180 - seems to be a very good case that im considering, but dont know how ill feel about having less space than my current full tower chieftec!
    only problem with the current one is its not quite deep enough - a 7800GT and hard discs do not go in together easily!
  8. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Lian Li v1000 for a smallish case or you could go for the big v2000, ive got one, its great! So much room and when the case was empty you could throw it in the air with one hand and catch it again. Altho it is very heavy when full! 8 HDDs do that to a computer!
    Its fairly plain to, only got holes on the front of the case which look really good personally, its round edges are nice and there are no sharp bits.
    hope to have helped
    GiGo
  9. Hiren
    Hiren mind control Moderator
    15 May 2002
    Centurion 5 is about the cheapest case of decent quality build you going to get. Sub £40 quality cases are few and far between.
