Windows C.A.R.S Pre alpha Development build released!
Discussion in 'Gaming' started by Gabkicks, 19 Oct 2011.
  1. Zinfandel
    Zinfandel Modder
    2 Aug 2010
  2. Elton
    23 Jan 2009
    So I finally get to drive Fittipaldi's, Rindt's and Senna's cars? AWESOME.
    Now if they can get some of the old Williams and McLarens in. That would make my day. And convince me to buy it.
  3. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Each time I play (or even leave the options menu after saving..).
  4. Gabkicks
    Gabkicks What's a Dremel?
    3 Aug 2010
    did you try doing a full unistall (removing documents\cars as well as main folder)? I
  5. AlexB
    AlexB Web Nerd
    22 Dec 2005
    yup. Seems intermittent :/
  6. silky
    silky What's a Dremel?
    25 May 2012
    Wow I just watched that hockenheim video and it was exciting! Looked so much fun its tempting me to get this game and a steering wheel and pedals...
  7. Gabkicks
    3 Aug 2010
    the car loooks Faaantastic!, but it just has placeholder physics ATM.
  8. AlexB
    AlexB Web Nerd
    22 Dec 2005
    I'm loving the previous build, but this latest one is a bag of crashes for me (and most of the WMD forum).
  9. MjFrosty
    MjFrosty Minimodder
    3 Aug 2011
  10. AlexB
    AlexB Web Nerd
    22 Dec 2005
    That looks great. I have a Fanatec Wheel Stand Pro in the loft and that looks very similar - nice work!
  11. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I'm kind of stuffed with this new launcher.
    It downloads the patches/game installer to C drive, can't seem to change this, and I don't have enough space on my C drive for it. :D
    Suppose I could create a junction, although it might be easier just to finally buy an SSD and be done with it, :D
  12. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    Thanks for the movies and links. Is "High" the highest settings or is there an Ultra or something? Also can you reduce the blur and stuff? I think I'm going to buy this, but I'll need to find a good price on a decent wheel with pedals first.
  13. bluespider42
    bluespider42 Minimodder
    2 Jul 2010
    You can change the patch location in the options menu, which is accessed from the launcher login screen.
  14. Gabkicks
    3 Aug 2010
    Thanks to the few people that listed me as a reference :) Hopefully we get multiplayer soon!
  15. Cerberus90
    23 Apr 2009
    Hadn't seen that.
    Looked in the forums but I obviously didn't look far enough in, :D.
    Anyway, downloaded 249 through torrent, and then let the launcher get the others, then it started installing. It started extracting the stuff to the C drive, presumably to a temp dir, so my C drive space dropped down to 81MB, and then I cancelled it as it wasn't going to fit, :D.
  16. Bokeh
    Bokeh What's a Dremel?
    30 Jul 2012
    Just a (sort of) hint, if you launch the game with ' -use3dscene ' in the target, you will get the 3d garage preview back again...but its hilariously glitchy and gives you a black garage (the reason they took it out of the build).
    Also if you are wanting to play this with dx11 ontop, you may have to add -dx11 as well.
    Apologies if this has been said already, I'm new to the forums :)
  17. Bokeh
    30 Jul 2012
  18. Bokeh
    30 Jul 2012
    Words cannot describe how much I am looking forward to rain! I just hope they bring out some wet-weather tyres sooner rather than later ... esp for the Formulas and the X4 Touring
  19. Bokeh
    30 Jul 2012
    Just played a bit of 277, loving the visual changes to Eifelwald. It is shaping up rather nicely!
    I tried rain (with the new particle effects) but for some reason it didn't render the sky so I ended up with rain and clouds in front of pitch black :/ . I will verify files and try again tomorrow, hopefully with better luck.
    Now I just need to find a good song to last the length of an Eifelwald lap in an X4 Touring!
  20. carebear
    carebear What's a Dremel?
    12 Jan 2011
    I didn't know there was a new build! I should check every week as I get weekly builds, duh.
    I'll have to re-download though because I re-installed windows a couple days ago.
    Overall the game is brilliant, I just need to fork out a steering wheel for it!
