Development C# Help please
Discussion in 'Software' started by NikoBellic, 21 Jul 2010.
  1. NikoBellic
    NikoBellic Tech Addict
    9 May 2009
    Is there any simple code that I can use similar to the code below which can close a running exe file rarther than starting it?:
    Code:
    private void button1_Click(object sender, EventArgs e)
                System.Diagnostics.Process.Start("explorer");
  2. mjb501
    mjb501 What's a Dremel?
    20 Jun 2010
    You need to do some thing like this:
    Code:
    class Form
            private Process p;
                p = System.Diagnostics.Process.Start("explorer");
            private void button2_Click(object sender, EventArgs e)
                p.Close();
  3. NikoBellic
    9 May 2009
    No luck unfortunately...
    I just get the following error
    Code:
    The type or namespace name 'Process' could not be found (are you missing a using directive or an assembly reference?)
  4. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Process.GetProcesses() should return an Arraylist of processes that can run.
    you can then iterate through it, and .Kill() the appropriate one by name comparision.
    i.e.:
    Code:
                System.Diagnostics.Process[] PArray = System.Diagnostics.Process.GetProcesses();
                foreach (System.Diagnostics.Process p in PArray)
                    if (p.ProcessName.ToLower() == "notepad")
                        p.Kill();
    The issue you have with the above example is that you'd need to declare Process as System.Diagnostics.Process rather than just Process, or include "using System.Diagnostics" beforehand.
    secondly, the above example would only close the task it created on Button1 press, where mine would close (all instances of) Notepad.
    Pick and chose, really.
  5. mjb501
    20 Jun 2010
    Woops, forgot to add the using at the top of the class!
    Code:
    using System.Diagnostics;
    class Form
            private Process p;
                p = Process.Start("explorer");
                p.Close();
    That means you don't need to type System.Diagnostics in front of Process every time you want to use the process class (only within that code file though!).
  6. BentAnat
    26 Jun 2008
    Yeah... using the namespace like that would make it work.
    To give a better example would really require more info though.
  7. NikoBellic
    9 May 2009
    the start of my original code is similar to as follows:
    Code:
    using System;
    using System.Collections.Generic;
    using System.ComponentModel;
    using System.Data;
    using System.Drawing;
    using System.Linq;
    using System.Text;
    using System.Windows.Forms;
    using System.IO;
    namespace app1
        public partial class Form1 : Form
            public Form1()
                InitializeComponent();
                    System.Diagnostics.Process.Start("control");
  8. BentAnat
    26 Jun 2008
    What exactly do you want to do?
    From what I can tell, you have a form with two buttons.
    Clicking Button1 opens explorer, clicking button2 opens Control panel.
    If you want another two buttons that close the appropriate tasks (i.e. one closes explorer, one closes control panel), then I'd recommend using my method ,and adapting like this:
    Code:
                    if (p.ProcessName.ToLower() == "explorer")
                        p.Kill();
                    else
                        if (p.ProcessName.ToLower() == "control")
                           p.Kill();
    or something along those lines (the above is one button that would close either explorer or control panel. Only one of the two at a time...
  9. NikoBellic
    9 May 2009
    The explorer & control commands are just examples,
    I want to make it possible to tweak one of these buttons so instead of launching an app, it can close any exe that is running on my computer (any exe that you can find in the processes tab in taskmanager)
  10. mjb501
    20 Jun 2010
    You need to use BentAnat's method then, but you maynot be able to stop all of Processes running on the PC because of administrator privledges!
  11. NikoBellic
    9 May 2009
    Thanx guys, just got BentAnat's code working now!...
    Sorry for being a "little" N00Bie
  12. BentAnat
    26 Jun 2008
    To make it more flexible, you might be able to adda textbox to enter a task name (i.e. "control") and throw that method at a function that closes all tasks with that description.
    you should be able to get reasonably far by just taking the conditionals (i.e. the if(){ and the appropriate } out of it, thus closing all tasks
    mjb is right in stating that you are very likely to run into issues like that, though, as it'll try to close a lot of things (i.e. potentially windows services, etc)
  13. BentAnat
    26 Jun 2008
    No probs. it can be a bit confusing if you're not a regular coder, as a little bit of code adaptation is always needed. :)
  14. mjb501
    20 Jun 2010
    Glad you got it working! I have done a bit of reading up on the Kill() command and it geneates an exception if you do not have admin privledges to end the process, so you need to handle them with a try catch statement.
    If you put the try around the p.Kill() it will prevent it from stopping you program when/if these occur. In the catch part I have put told it to show a MessageBox saying it cannot end the Process if this happens.
    Code:
                                 try
    	                p.Kill();
    	            catch (Exception)
                		MessageBox.Show("Could Not End Process!");
                    else
                                 try
    	                p.Kill();
    	            catch (Exception)
  15. NikoBellic
    9 May 2009
