Modding Cable Brading
Discussion in 'Modding' started by Cruelinios, 28 Jul 2002.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    * bump *
    Oclocker - are you up to supplying some braid, then?
  2. Annon
    Annon What's a Dremel?
    22 Mar 2002
    I just ordered some of the chrome expandable sleeving from that site, I'll let you guys know how it works.
  3. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    how much was delivery of the cabling to the UK??
  4. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    it works good, just watch out for snaggies since the weave has thin fibers (like tinsel, but thicker). Also you'll find that chrome is actually more tubualr compared to silver which is rolled flat on a spool.....
  5. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    On wirecare they can round the flatter kinds for a little bit extra per foot (10 cents maybe?) I got some on my smaller sleeving I ordered from them, so we'll see how it turns out
  6. Cruelinios
    21 Jan 2002
    how much did u say delivery was???
  7. Floydian
    30 Dec 2001
    I think delivery was between 4-5 for standard shipping (inside the us)
  8. Annon
    22 Mar 2002
    I wouldn't know as i'm in the USA. :D
  9. GreySpaceAlien
    GreySpaceAlien What's a Dremel?
    27 Jul 2002
    That chrome is looking pimp, gotta get me some of that!
  10. GreatOldOne
    29 Jan 2002
    Re: Re: Re: Re: Cable Brading
    Bump'n'Quote:
    Oclocker - are you recieving me?:D I'd like to buy some braid!!
    [EDIT] - YGM, OC....
  11. jethro
    jethro Modthusiast
    19 Mar 2002
    what size braid is the right size for a psu cables?
  12. Woody
    Woody What's a Dremel?
    11 Nov 2001
    Re: Re: Re: Re: Re: Cable Brading
    I second that, I want some too:D
  13. Floydian
    30 Dec 2001
    1/4in is alright, with 3/8in heatshrink, BUT this is sort of small, it looks like on the antec fan they used 1/4in stuff -- if you use 1/4in on your power cables, the color of the wires inside will show out, you have to leave it expanded (if that makes sense)
    I'd suggest maybe buying 3/8inch stuff, with 1/2 in heatshrink maybe, it would be a little bigger, and would be a more solid color (solid black instead of "expanded" black)
    Make sense?
    I can post some scans of what it looks like, I have the black Flexo Pet in 1/8in and 1/4in from the wirecare.com site, as well as some 3/8in heatshrink (damn, i forgot to get the smaller heatshrink for 1/8in!)
  14. StuckShut
    StuckShut What's a Dremel?
    8 Aug 2002
    Note to self... 2 pages mean that responding to the conversation on page 1 will most likely confuse everybody else :p
    pay no attention to this post *waves hand in jedi-like fashion*
  15. jethro
    jethro Modthusiast
    19 Mar 2002
    Makes complete sense.. Thanks
  16. reg36
    reg36 What's a Dremel?
    10 Jan 2002
    Check out the reflective braid at wirecare, the possibilities hmmm.
  17. cutplug
    cutplug What's a Dremel?
    21 May 2002
    www.frozencpu.com also sells the braided wire loom if you are looking for a site in the US that sells it.
  18. Floydian
    30 Dec 2001
    :eeek: egad, frozencpu sells it for 2.50 a foot.... wow
    wirecare.com much better deal IMO
    Check out the "flexo wrap", I didn't know what this was, but apparently its expandable sleeving w/some velcro-like edges split down the edge, so you can wrap it around cables, like the ATX cables, wish i had ordered some now :/ that split-loom over my ATX cable with everything else sleeved looks so lonely :eek:
    here's the link for it
  19. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    yes - sorry very busy _ need to reorganise me business to get moe time - but no time for tahts cos too busy :(
    Just email me oclocker@baybus.co.uk - but need to know what size cables etc..
  20. Phire
    11 Jan 2002
    Actually you are quite incorrect. 1/8" is the size used on antec fans, and my braiding that I am selling does not show cables even when fully expanded....1/4" is plenty for the 4 wire molex and can even take the 6 wire AUX connectors with no problems. 1/2" heatshrink is WAY too big for anything other than Midi or serial ribbon cables and you can even use 1/4" on 40 pin ide cables and still habe no wire showing. Not to be an asshat but trust me, I have used this stuff quite extensively and in much more sizes/applications than you.
