Hardware Cable Modders PSU Modding Supplies review
Discussion in 'Article Discussion' started by brumgrunt, 14 Feb 2013.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. blackworx
    blackworx Cable Wrangler
    31 Jan 2008
    Tsk you young'uns don't know how good you've got it. Time was you had to make a bit of effort sourcing parts if you wanted to cable mod properly, now it's just handed to you on a plate! Grumble grumble moan moan etc.
  3. Combatus
    16 Feb 2009
    :D All we need now are some capacitors and a circuit board and we'll be making our own PSUs next!
  4. law99
    law99 Custom User Title
    24 Sep 2009
  5. Combatus
    16 Feb 2009
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I actually think the 18awg wires look a lot nicer than the shrink wrapped cables.
    One question I would have about making my own cables is that when making pass through cables for devices with either Molex or S-ATA connectors, what is the maximum you can have on a single line? What is the equation to work out how many device you can have on a single rail?
  7. law99
    24 Sep 2009
    I tried to figure out what was happening by looking at it and gave up. Was too hard.
  8. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I don't length will ever be an issue unless your pc is the size of a room, literally.
    Working out how many devices you can have on one rail / cable is 'merely' a case of knowing the max current draw of each device, vs how much current the wires & rail can support. A PSU with a single 12v rail is usually rared for anything between ~20 to 50amps, though an individual ~18g wire is rated for 2.3amps ordinarily ( will happily take more, but temps will increase and voltage drop will become a factor ):
    http://www.powerstream.com/Wire_Size.htm
    I used Cable Modders stuff in my project, nice quality stuff though not the most flexible- that's the issue with the insulation they use on the wires though. I'd love manufacturers to use silicon insulated wires like you find in more high-end electronics... ( R/C industry for examle :D ).
  9. Combatus
    16 Feb 2009
    The maximum would be determined by the power available on that particular rail (all this info should be available from your manufacturers website) and the draw from the devices you want to connect. However, it can be a bit tricky identifying individual rails as sometimes one SATA and Molex cable can be on one rail, and another can be on another rail, each with different limits. Unless you have diagrams and can take the PSU apart (danger, death, kill!) to be 100% sure, I wouldn't recommend adding more connectors (one or two more probably wouldn't hurt, but don't quote me on that!)
  10. SchizoFrog
    5 May 2009
    Thanks for the response... I ask because I have a 600w Be Quiet PSU and on the device rails (HDD, Optical Drive... Etc) they have a couple S-ATA connectors and then some molex or the old Floppy Drive style connectors. So to power up my 5 HDD's and Optical Drive I have to use both rails which is both untidy and space taking. If I could create a single rail for all those devices then that would be ideal, but as mentioned I would have to know the figures to get the right power.
  11. Combatus
    16 Feb 2009
    Oops I think I just repeated a lot of what SuicideNeil said as he got in first!
  12. Shirty
    18 Apr 1982
    Back in my day you had to weave your own sleeving, smelt your own copper wire and GPUs were pedal powered.
  13. Guest-23315
    Guest-23315 Guest
    Must not comment on sheer hatred of individually sleeved cables...
  14. SchizoFrog
    5 May 2009
    Must get reasons... :)
    What do you hate about them? Just the look?
  15. jrs77
    jrs77 Modder
    17 Feb 2006
    The wires and the braiding arent the problems really. The crimping-tools are, as a good one costs some $40 allready, and then you need to have a source for the crimps and the connectors, and they aren't cheap either. Especially SATA-crimps and connectors are hard to find and the only source I know of where you can get all of the stuff in one place is MDPC.
    Rewiring a PSU, with all the stuff included costs some serious money, especially if you don't mod your PSUs that often, as the tools cost asmuch as a new PSU allready.
    Simple braiding is much cheaper to realise, as you don't need anything else then a pin-remover and a heatgun (a lighter works aswell).
  16. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Better question for the extreme lazy. Can we not take our rigs to someone to do this for us for a price?
  17. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    I have spent many an hour braiding cables in the past and whilst it looks great, I can't say I enjoy it.
    If I was going to do it again, I think I would go down the route of re-wiring it all rather than braiding.
    For my current project I have cheated. I bought the Corsair cables that are braided. I have to be honest, they look the dogs. The only issue is that you don't get to pick the adapters you want and the cable lengths.
  18. ev1lm1nd666
    ev1lm1nd666 What's a Dremel?
    23 Apr 2009
    What in the name of all that is holy did that guy do? Looks to me the guy tried to re-create the water-pipe mini game from BioShock 2 while on mind-bending drugs lol
  19. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    I dont think i have the concentration level to do my PSU ill probably have a fit of rage half way though and chuck the whole lot out the window so thats why i bought a set of red corsair cables
  20. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    Roll on the extinction of cables
Tags: Add Tags
