CPU Can a C2D E8300 run with 800MHz Ram
Discussion in 'Hardware' started by isaac12345, 3 Dec 2015.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi all,
    I am going to upgrade an old Core2Duo machine from an e4500 to an e8300. It says that the e8300 has a 1333 fsb. Does that mean I would need to upgrade my RAM to 1333MHz or above or can I run it with my current ddr2 800 ram? Thanks!
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    It'll run it no problem. I've got an E8500 (1333MHz FSB) running with some 800Mhz RAM with no trouble whatsoever. Just make sure you check your BIOS settings so that everything is running at the correct speed (will probably auto-detect the RAM and adjust itself, but if not you can change the FSB:RAM strap yourself).
  3. isaac12345
    20 Jul 2008
    Cool! Thanks! :)
  4. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    The fsb:dram ratio is normally 1:2, so 667mhz is stock dram speed for a 1333mhz fsb. Some motherboards support other ratios so you can run the ram at 800mhz, but, this is bit-tech - overclock it! :)
