Displays Can d-sub display 1680x1050?
Discussion in 'Tech Support' started by sourdough, 11 Aug 2011.
  1. sourdough
    sourdough Minimodder
    17 Sep 2010
    my beloved 22" CRT has come to the end of it's life, I have an old LG L225WS laying around so I connected it up. However, i am having a hard time getting it to it's native 1680x1050. At first I thought it's because W7 was detecting it as a Generic non PnP but nothing changed after I managed to find the correct driver for it. Display card is HD5770 with latest driver from windows update. The closest resolutions on the list are 1400x1050, 1440x900, 1600x900 and 1600x1200.
    There is also the possibility of the EZ zooming button at the front of the monitor but nothing happened when I pressed it. Any thoughts please?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    VGA supports that resolution.
    Try installing the proper ATi driver for that card to get the resolution to show up
  3. adam_bagpuss
    24 Apr 2009
    create a custom resolution if all else fails and force it right
  4. sourdough
    17 Sep 2010
    tried the method on this thread but it's not showing up in CCC.
  5. sourdough
    17 Sep 2010
    I installed the version 11.5 of the Catalyst Suite and the new AMD Vision Engine Control Center seems to have taken care of it.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    see if you can find a driver specific to your monitor
    oops just re-read you have done that already
