Other Can I use and Xbox 360 in conjunction with my PC?
Discussion in 'Hardware' started by mikemorton, 29 Oct 2012.
  1. mikemorton
    mikemorton Minimodder
    5 Nov 2010
    Is it possible to hook up an Xbox 360 to my current PC monitor and speakers without having to constantly swap cables?
    I don't own the Xbox yet, so haven't had the chance to look at the set-up.
    I'm guessing the monitor (Dell) is easy enough, but I'm not sure if some sort of simple switch unit is available for the speakers.
    What do you think is the best option?
    Thanks.
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    yes if it has an HDMI input.
  3. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Does your Dell monitor have multiple inputs? eg, HDMI, DVI and VGA?
    If not, you'll have to deploy some sort of video switch box or KVM.
  4. mikemorton
    5 Nov 2010
    Hi guys, yes, the monitor has the required inputs.
    I assume if the PC is off, the monitor will take the next available data - ie from the Xbox 360.
    What about the speakers though? (Logitech Z906 if that makes a difference).
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    You can get 3.5mm jack splitters and they work, but I'm not sure how they affect sound quality.
  6. mikemorton
    5 Nov 2010
    OK, thanks for the tip.
    And all because I want to play Halo 4!
  7. mm vr
    18 Nov 2007
  8. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
  9. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    No no no just use the toslink/optical input for the XBOX (if you have a newer XBOX) or hack the original audio out put to remove the little tab or buy the audio out cable (same as original with out the tab)
    your speakers have enough input to not need a splitter cable.
  10. mikemorton
    5 Nov 2010
    Excellent - thanks guys. My wife has banned the Xbox from the living room, so into the study it will go :)
  11. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    XBOX support page
    with pics :D
    Newer XBOXes have a optical output which would be best for your speakers check for the toslink cable output at the back of your xbox.
  12. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    I use the 360 VGA cable and the phono to 3.5mm jack, easy peasy
  13. mm vr
    18 Nov 2007
    Toslink all the way if your speakers have such an input. :)
