Electronics Can you cut LED strips?
Discussion in 'Modding' started by Vault-Tec, 23 Sep 2016.
  1. Vault-Tec
    30 Aug 2015
    I'm sure I read that you can. Thing is I am worried about cutting them in the wrong place and killing them.
    So can you? and if so if I upload a pic could some one tell me the cut points?
    Cheers :)
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
  3. Vault-Tec
    30 Aug 2015
    Mine are not like that fella. I will try and get a pic of the back side/traces tomorrow. They were like £1.12 for two lol. IIRC it's three LEDs per resistor, so it should be manageable.
  4. Vault-Tec
    30 Aug 2015
    Any idea if they can be cut?
  5. Vault-Tec
    30 Aug 2015
    NVM figured it out. You can cut them :)
