Other Cannot get my new system to boot!!
Discussion in 'Hardware' started by jasongreen_89, 29 Feb 2012.
  1. jasongreen_89
    jasongreen_89 What's a Dremel?
    25 Feb 2012
    I'm at my wits end with my new build. Bought everything a couple of weeks ago and could never get the system to boot for more than 1 second. Sent everything back to Scan and they said the memory was faulty (which seemed quite unlikely).
    I received my goods back today with a new set of memory, put it all together and it still wont boot up! Can someone please help!
    My spec is:
    Asus P8z68-V GEN3
    i5 2500k
    Corsair 8GB 1600MHz.
    Cooler Master 500w PSU
    Im using the standard heatsink and have no other components connected. If i press the on button the VGA button lights once and at the same time the CPU light comes on twice very quickly then turns off. If i hold down the power light the CPU light blinks 4 times but I'm not sure if this is related to the problem. I have checked the ATX CPU power is plugged in correctly and the heatsink is on tightly.
    Has anyone got any suggestions to try?
    Thanks in advance
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Are you using integrated graphics?
    Do you also have the 8pin atx cable in?
  3. jasongreen_89
    25 Feb 2012
    Yes I'm using the motherboards on board graphics. Yes my PSUs 8pin ATX is in.
