Cant find a part I want/need
Discussion in 'General' started by kongen, 4 Feb 2005.
  1. kongen
    kongen What's a Dremel?
    15 Jan 2005
    I have been searching high and Low for a peice part I need a small acrylic box open on one side closed on the other. It only has to be around 1" by 1" with a depth of no less that .5" I cant find it anywhere I have a sweet idea but I cant find a clear box that meets this requirements. I dont want to let the cat out of the bag yet but anyone think of anything I could use for this? :wallbash:
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    make one up yourself....only way to make something truely unique...
  3. JeremyM
    JeremyM What's a Dremel?
    31 Jan 2005
    Yeah, it wont take much to make one that size. It's easy.
  4. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Many stamps (wooden block + ink pad) come in a small acrylic box. Check your local craft stores out. Mind you for the cost of the stamp you could probably make a cheaper box yourself and have material left over.
    Try looking in Crazy Mad $2 Junk Warehouse Clearance type stores for something cheap in the right size box?
  5. kongen
    15 Jan 2005
    Cool thanks guys I am still un sure of what I want to do at this point but I will let you all know how it comes out in the Modding area. :dremel:
