Linux Cant get ndiswrapper working
Discussion in 'Software' started by Who_me_33, 26 Jul 2006.
  1. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    As the topic states, ive fresly reinstalled, and am now trying to use ndiswrapper for my wireless netowrkcard (rather than the one built into the kernel) (its a bcm4318).
    I can go through all the steps nicely, no complaints (I used the linva resp' for the ndis module). When i issue the command ndiswrappper -l I get
    Code:
    Installed drivers:
    bcmwl5          driver installed, hardware present
    and then do depod -a, and then modprobe ndiswrapper, but in dmesg I get (only the last little bit, as as far as I can telll that is all that is relevant.
    Code:
    ppdev: user-space parallel port driver
    ppdev0: claim the port first
    ppdev1: claim the port first
    ppdev2: claim the port first
    ppdev3: claim the port first
    audit(1153943731.772:4): avc:  granted  { execmem } for  pid=2298 comm="Xorg" scontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=process
    audit(1153943731.776:5): avc:  granted  { execmem } for  pid=2298 comm="Xorg" scontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=process
    audit(1153943731.776:6): avc:  granted  { execmem } for  pid=2298 comm="Xorg" scontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=process
    audit(1153943731.776:7): avc:  granted  { execmem } for  pid=2298 comm="Xorg" scontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tcontext=system_u:system_r:xdm_t:s0-s0:c0.c255 tclass=process
    ndiswrapper version 1.18 loaded (preempt=no,smp=no)
    [root@localhost bcmwl]# /usr/sbin/ndiswrapper -l
    by the way, my system is fedora core 5, with the 2.6.17-1.2157_FC5 kernel. (yes, this is related to my wpa problems, but ill climb that hill again when I get to it, i managed to completly kill my install).
  2. Glider
    Glider /dev/null
    2 Aug 2005
    I think it should be working? Can't you get the wpa_supplicant working with the native linux drivers? (don't have to be in the kernel, Modules will work too)
  3. Who_me_33
    26 Oct 2004
    When i was compiling wpa_supplicant, with the broadcom driver option, it wasnt compiling. But ive figured out my mistake, I had forgot to blacklist the broadcom driver. And the reason behind using the ndiswrapper this time through, was a lot more people seemed to be using it, so it should be easier to get support for.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Yeah, ndiswrapper is often used, but I tought mostly for chipsets that don't have Linux native support. I was lucky, I got 1 card that wouldn't work in any way, and 1 with native support...
    I allways try to stay as native as possible, and emulate as least as possible...
