Case Mod - In Progress Captain Marvel - Quantum Mod
Discussion in 'Project Logs' started by i2r, 15 May 2019.
  1. i2r
    i2r What's a Dremel?
    19 May 2017
    Hi guys,
    i just wanted to wrap up a work log for a mod i am working on since last year.
    Due to the release of the film i didn't want to push it out before that. Now Endgame is also running, so i thought why not put a little worklog together for my "still" ongoing mod.
    Case (MC500P) and CPU cooler (MasterAir G100M) are sponsored by Coolermaster.
    The board (H370M-ITX) is sponsored by AsRock.
    A quick overview:
    I wanted to create a Captain Marvel mod prior to any spoilers that might or might not be true after watching Infinity War, where Nick Fury sends out a distress call with his pager.
    The idea was to go for a suit like look, which i managed to do with synthetic leather.
    Also i was pretty sure back then, that the Quantum-Realm (introduced in AntMan) would play a part of either Captain Marvel or Endgame.
    So for me was clear that i want to get some kind of Quantum going...which i ended up doing with a LCD sidepanel.
    I also tried to create a pager, which could be used as a mobile phone and also as a remote power button for the PC.
    Still not finished but for sure in the "Endgame". :)
  2. i2r
    19 May 2017
    so basically after recieving the case i started to wrap stuff with synthetic leather.
    the more delicate part i had thick paper wrapped with it and for the bigger parts i used foam rubber mats.
    K1024_IMG_20180928_161848.JPG K1024_IMG_20180929_123032.JPG K1024_IMG_20180928_185455.JPG K1024_IMG_20181129_012138.JPG
    for the pager i printed a case that fits on my old xperia z3 compact.
    K1024_IMG_20180812_104253.JPG K1024_IMG_20180812_110907.JPG K1024_IMG_20180812_115624.JPG K1024_IMG_20180905_134728.JPG
  3. i2r
    19 May 2017
    the hardest part was to get the frames done. yes they're all printed but still they broke occasionally, some colors were nice but did not last (couldn't be coated) and so on...
    K1024_IMG_20181221_174009.JPG K1024_IMG_20181221_183300.JPG K1024_IMG_20181221_184927.JPG K1024_IMG_20181221_184940.JPG K1024_IMG_20190308_084936.JPG
    putting in the lcd was not that hard once it was disassembled and i found the right way to power the circuit board.
    i reused the backlight acrylic of the monitor as a rgb psu shroud and to cover up holes in the case where the cages for HDDs and other drives were.
  4. i2r
    19 May 2017
    because my black Palit GTX 1060 would not fit the theme and i also decided not to paint it (whole inside of the case got silver) i tried to print my own GPU Cover, which worked out pretty well.
    K1024_IMG_20190127_000808.JPG K1024_IMG_20190127_121433.JPG K1024_IMG_20190128_114217.JPG K1024_IMG_20190128_122131.JPG K1024_IMG_20190128_142745.JPG K1024_IMG_20190130_112013.JPG K1024_IMG_20190203_115941.JPG K1024_IMG_20190203_115948.JPG K1024_IMG_20190203_152406.JPG K1024_IMG_20190203_155123.JPG
  5. i2r
    19 May 2017
    i painted as much as i could in silver to get a good reflection for the lcd which sits behind the tempered glass.
    K1024_IMG_20190417_152901.JPG K1024_IMG_20190417_152913.JPG K1024_IMG_20190417_152918.JPG K1024_IMG_20190417_152922.JPG K1024_IMG_20190417_153807.JPG
    pretty much done (steps could be probably alot more detailed), and small things left to do like details, finishing up the pager and closing the gap between front and psu shroud/plate.
    K1024_IMG_20190417_154509.JPG K1024_IMG_20190417_154509.JPG K1024_IMG_20190417_154655.JPG K1024_IMG_20190417_155525.JPG K1024_IMG_20190417_155634.JPG
    MLyons likes this.
