Modding Carbon Fibre Mod for my shuttle and more to come
Discussion in 'Modding' started by paulmofyourhand, 1 Sep 2004.
  1. paulmofyourhand
    paulmofyourhand What's a Dremel?
    1 Sep 2004
    and this is my 120>80mm fan conversion , i am running the push pull config, and its running veryy cool, 40c idle 49c load,
    2500+ mobile @ 2400mhz (30hrs prime stable)
    corsair XMS pc3200LL @ (2-3-2-11) stock voltages (damn rev.2 death)
    2- 80gb WD in RAID 0 w/ Promise TX4
    Radeon 9800 pro
    generic 8x dvd burner
    modded-
    *carbon fibre face (its the carbon fibre fake tape thing, looks real!)
    *black sharpie the front audio ports to blend with the black c/f
    *120mm>80mm converter w/ enermax 120mm fan
    *80mm coolermaster LED fan zip tied on the ice to complete the push pull config
    *Zalman nb47j northbride heatsink (make sure you lap these, they are very concave)
    *cut the rear fan grill
    *cut the side grill (runs just as good with the case off , +/- 2c ,)
    *PN11 wireless antenna
    *60mm fan mounted on bottom of hard drive cage, over the ram/nb area
    plans-
    *rear handle for lans
    *250w silent x psu
    *a 20 LED shine ;)
    * -suggestions- *
    awaiting-
    *money
    *mobo to come back from RMA, til then , mod time!!
    what you guys think?
  2. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    Apart from the scuffed front on the close up, it looks great. I would suggest putting some mesh behind those small slits at the bottom though as it'll look a lot nicer :) . Good idea with the fan too.
  3. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    That reminds me of my old shuttle sb51 :)
    Got to love carbon fibre :)
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Looks good. You can polish-out that plexi-scrach no problem. The CF stuff works well. I used it on my project BN's DVD drive.
  5. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    I don't mean to go OT but can the 'CF stuff' fix scratches in Lexan as well? And what does CF stand for/what does it look like?
  6. dom_
    dom_ --->
    4 Jan 2004
    where do you get this carbon fibre fake stuff?
  7. paulmofyourhand
    1 Sep 2004
    CF = carbon fibre ,
    R@mo sutff doesnt fix the scratches, its that black square design material in the pics, but my stuff is fake, he was talking about that another thing fixes the scratches
    my friend gave it to me, you could try the aftermarket car catalogs for this stuff
  8. modsquad
    27 Feb 2004
    Sorry for the confusion guys. Try NOVUS heavy scratch remover for the plexi/lexi. and rub like crazy........
    and you can get the "CF" stuff from frozenCPU
    MS
  9. paulmofyourhand
    1 Sep 2004
    i scored another shuttle sn45g motherboard (the ver.1 !!!! wooot) and another 2600+ mobile, and G2 case from shuttle
    im thinking of building a mini mini mountain mods case, but with two of these boards,
  10. fg0d
    fg0d Banned
    18 Jan 2004
    where you getting your CF? in america by the looks of your member info. I am looking for a supplier but ive been having some problems myself. Help much appreciated
  11. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
  12. fg0d
    fg0d Banned
    18 Jan 2004
    eww I dont want film :( i want real fabric!
  13. dreamreality
    4 Mar 2003
    good luck finding it :p not sure where they sell the real 'fabric'
  14. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    TAP Plastics sells everything you need for carbon fiber
  15. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Also, you can usually find sheets of REAL Carbon Fiber on Ebay (US or UK) for really good prices... :thumb:
  16. Silverstrand
    Silverstrand What's a Dremel?
    29 Jun 2004
    Carbon fiber seems to be the new style of mods. It's popping up everywhere now.
  17. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Moving to modding
  18. Firehed
    15 Feb 2004
    Yeah, because it has an awesome look :) I was planning to try it myself but the availability locally (for all the mod parts, not just CF) is so limited I basically started from scratch. And a small form factor with a radbox on top isn't that small anymore :hehe:
  19. DanMcr
    DanMcr What's a Dremel?
    27 Jul 2004
    Looks nice to me. Anything Carbon Fibre goes on my bike though. :D
    As for where to get real material. You can buy A4 sheets of it at most Motorbike accessory places. You can get the fake stuff as seen above, but Motrax i think sell the real stuff aswell. Its pretty flexible and is sticky on one side, so a piece of cake to work with.
    Edit - Here you go http://www.motrax.co.uk/Index_pages/accessories/flexicacut.htm
    They also do it in different colours, titanium weave, aluminium weave etc.
