Having seen this http://forums.bit-tech.net/showthread.php?t=199733 I’m a little worried about sending my case to be cut by chilled pc. Any one had any negative issues with this? Was only going to be a window for a TJ07 for the side panel as mine currently does not have this. If you can suggest else where as well that would be good too. Won’t be sending till all the snow is gone so no rush. Also anyone know where to get a custom front to cover all the drive bays like murdermod as I would love one but they don't seem to be making them at the moment. Thanks.
Have a search around your local area for industrial laser cutters. Take them the panel, and the file (.dwg/.dxf etc) for the profile you want cutting out and see what they can do! Cheers
Chilled PC is good. Have done a lot of stuff with them and they are pretty good at what they do. I would not be worried about their work.
Pardon me for saying it but I find that statement hilarious - http://forums.bit-tech.net/showthread.php?t=199733 I think you may then form a different opinion
Had a look at there page and they look good have ask them for a quote will hopfully here back before xmas. Thanks
