Modding Case designs would like opinions
Discussion in 'Modding' started by x06jsp, 16 Apr 2008.
  1. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    Hi there these are a couple of cases that i have designed that i may sell through my site www.overclockerzwatercooling.com and i would like your opinions on the designs
    Ok the first one is 744x644x220 mm (hxdxw) (before you say yes it is quite like the tj07 but it is different in many ways too.
    and the second is a 'cube' and it is able to fit up to 2 pa120.3's and 3 120.2's at once aswell as 8 5.25"bay devices and 6 harddrives i know noone will need all this i have just included the rads to prove it can be done.
    p.s. the design is not quite finished (top and bottom front wont be open)
    it is 500x500x550 mm (wxhxd)
    so what do you think of the two?
  2. blu
    blu New Member
    22 Oct 2007
    on the tower, have you thought about shortening the window so that you dont see much of the top rad, it just seems that with this tower you want to focus on the motherboard, gpu, cpu, and probably all the tubing that would be used for the wc setup.
  3. Mo_
    Mo_ Did this world come by chance?
    7 Apr 2008
    Nice design:clap:! which program did you use?
    There's only one thing though; Will you not put a mesh/cover on the bottom front fan? (1st pic)
  4. x06jsp
    2 Apr 2007
    i use sketchup from google :thumb:
    and yes i would use mesh i just didnt in the design...
    at blu thanks i will give it a go.
    thanks for the comments keep them coming
  5. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    I love the tower! I'm not much of a cube fan but it seems like it would work quite well. I agree with blu, I would make the window smaller on the tower.
    Google Sketchup - It's free!:D
  6. x06jsp
    2 Apr 2007
    thanks thacrudd :thumb: ill post up an altered one later on
  7. x06jsp
    2 Apr 2007
    ok here it is with the smaller window and in black and white (just one of the colour schemes that are available...
  8. x06jsp
    2 Apr 2007
    im going to build both of these at the end of june/start of july as i dont have the funds available at the moment so that i can post it on forums and on my site for sale as i need a couple of prototypes.
    I will make them earlier if someone is that interested in buying one or even a few people. the more people that want it the cheaper i can make it. so if anyone wants one please pm me
    josh
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    they look pretty good :thumb:
  10. x06jsp
    2 Apr 2007
    why thankyou :thumb:
  11. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Brilliance. If I might make a suggestion... Some form of interesting grille with some mesh, instead of the two fan guards on the side? Maybe the Overclockerzwatercooling logo?
  12. x06jsp
    2 Apr 2007
    ooooh that could look quite good thankyou!
    and thankyou very much for the compliment!
  13. x06jsp
    2 Apr 2007
    anyone else got anything to say about them??
    josh
  14. KayinBlack
    KayinBlack Currently Rebuilding
    2 Jul 2004
    I really like the cube case design. Some of us really do try and fit all that in one case...
  15. x06jsp
    2 Apr 2007
    im currently working on another cube aswell its a bit bigger :eeek: but it is looking good so far
  16. x06jsp
    2 Apr 2007
    been speaking to a company about getting some cases manufactured and im going to see him at the end of june to discuss it :thumb:
    so if anyone has any ideas for designs get in touch
  17. badders
    badders Neuken in de Keuken
    4 Dec 2007
    What prices are you looking at for the tower?
  18. x06jsp
    2 Apr 2007
    not sure yet hopefully cheaper than the tj07 (which is a good deal seeing as its alot bigger and will be very very good quality
    i wont know any real prices though untill i have spoken to the manufacturing company though.
    but if anyone is interested before then i will also custom make these for you.
    josh
  19. badders
    4 Dec 2007
    hopefully cheaper than the tj07?
    Yikes.
    Not for me then, unless it's £150 cheaper.
  20. x06jsp
    2 Apr 2007
    umm well if it was 150 cheaper i would be selling at a loss, aluminium, acrylic, fans, power etc etc it all adds up! and seeing as they need quite alot of alu that is only a bit more than just the alu would cost. seeing as the tj07 is 200. these will be enthusiast cases for the people that are into lian lis etc etc
