Scratch Build – In Progress case kenya mod (update render n materials )
Discussion in 'Project Logs' started by trinity1000, 11 Nov 2010.
  1. trinity1000
    trinity1000 What's a Dremel?
    11 Sep 2010
    hi guys
    case kenya will going to be my fourth mod .this case is basically a design that was bothering me in my head for the last two months and finally i put the idea into paper . the project will be done as a group from guys who are here in kenya too.
    the design is inspired from the shape of kenya .i won't talk to much about the walkthrough ,mainly the pics will tell .
    playing with colors
    materials
    aluminum "L" shape for the frame
    aluminum 8x4m x1mm plain sheet
  2. FOReVER_NOOB
    FOReVER_NOOB What's a Dremel?
    10 Nov 2010
    Very original. I like it!
  3. shoxicwaste
    shoxicwaste Minimodder
    2 Jul 2010
    Loving the shape!
  4. Attila
    Attila still thinking....
    22 Feb 2008
    Welcome to bit-tech. :)
    Those concept drawings look to be on the plus side of awesome. What materials are you planning on using?
  5. bulldogjeff
    2 Mar 2010
    Arghhhhhh!! Attila, you got 666 posts:jawdrop:
    The renders look cool, would be really good to see it come to life.
  6. aaron
    aaron Ally of the Porcelain War
    4 Jul 2009
    Intriguing shape. Be good to see this come to life :)
  7. trinity1000
    11 Sep 2010
    @attila i will be using a 2mm aluminium sheet of the top front and back,4mm for the frames and 5mm for the side panels...
    thanks everyone else ..i cant too wait .now let me get to work
  8. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    maybe use a bit thinner sheet for the side panels. The design is very cool. you can work on the renders though. You can get a lot of great advice HERE. I will be following this.
  9. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    4mm and 5mm thick materials are pretty heavy mate. They are going to add a lot of weight to your case just for unnecessary strength. 5mm material is pretty close to the American 6ga material which is very heavy stuff. Its a lot thicker than you would think. I work in the RnD department at a company who makes wood stoves and fire places and we have a steel stove line. Our steel stoves bodies are made out of 3ga, 7ga and 10ga and they are heavy as hell and stand up to a lot of use+immense heats. Considering the abuse those things take I think an 14ga or 16ga material (about 1.6mm for 14ga and 1.3mm for 16ga) would be plenty especially if you design your parts with bends to improve structural integrity. We also have a BBQ line and the heaviest material we use on those is 18ga. Given its Stainless steel and not Al but even so. I would strongly recommend using a lighter material for this build unless you plan on abusing the living hell out of it or stacking large amounts of weight on top of it
  10. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Looks interesting :thumb: Looking forward to see how will you build the frame... It depends on how you want to joing the parts together, but I would think that 4-5mm for frame and 1.5-2mm for the rest would be ok....
  11. sixfootsideburns
    6 Feb 2009
    agreed, if your design was done well which which seems to be the case by the looks of it then this should be just fine
  12. Razer2007
    18 Jul 2010
    well even 3mm for some of the panel parts. for instance don't use 1,5mm for a big flat panel, it can be flimsy. but 2mm is perfect for most of it.
  13. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    That's a nice design for sure
  14. mr.sh
    mr.sh FEAR
    31 Jul 2009
    Look very interesting.
    Looking forward to see more.
  15. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I like the loom of this
  16. trinity1000
    11 Sep 2010
    thanks for the tip
  17. trinity1000
    11 Sep 2010
    thanks all modding gods for the info lol
    i will redo my render again cos i have only touch the render program 3ds max in a week ..im still getting around it
    so im gathering tools to use
    smaller drill
    10 different size drill bits
