Case Mod - In Progress Case Mod Index and Scratchbuild Index - submit your projects!!
Discussion in 'Project Logs' started by Combatus, 24 Jan 2012.
Thread Status:
Not open for further replies.
  1. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    We've recently launched the bit-tech case Mod Index, which is a database of mods, sorted by case manufacturer and case model. The idea behind it is that if you're looking for inspiration with your case when it comes to modding or installing water-cooling hardware, you'll be able to quickly find projects that have used your particular case.
    We've also launched the Scratchbuild Index - you guessed it - an index of scratchbuilds. They sorted by motherboard size, case type and materials used. Wanna see what mini-ITX cases people have made? Maybe all the cases that use composite materials? Head over to the Scratchbuild Index to see.
    We need your help to grow the databases so if you'd like submit your mod or scratchbuild, email us at modding@bit-tech.net with 'Submit My project' in the subject line.
    With mods, they must be complete with noticeable modifications (these can include spray paint/powder-coat or installed water-cooling hardware. You'll also need to include the following information:
    • Forum name
    • Case (make and model)
    • URL to your project log (which must be in bit-tech's project log forum)
    • Whether or not your PC is water-cooled
    With scratchbuilds we need:
    • Your Forum name
    • Project name
    • Motherboard type (ATX / Mini-ITX / Micro-ATX / Other)
    • Case type (tower/cube/desk/HTPC/Other
    • Primary material (acrylic/metal/wood/composite/other)
    We'll be adding to the databases regularly so be sure to check back to see all the new projects! :thumb:
Thread Status:
