Windows CD Burning under XP
Discussion in 'Software' started by Forsaken, 4 Nov 2001.
  1. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    What do you lot use for burning with XP, used to use nero with win98, but it dont detect me writer with xp :(.
  2. lowtech
    lowtech What's a Dremel?
    24 Oct 2001
    i use Easy CD v5 inc latest patch...works well (as long you dont inc direct cd and Take two)...:D
  3. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I agree with Lowtech CD v5 Platinum edition but you will need the patch, as XP will not be happy, it comes up with all sorts of errors.
    I use the HP 8200e USB CDR and needed the USB patch released by HP. Took me ages to get all the right drivers on?
    Only got all working on Sunday haven't had chance to prove its working but it seems happy enough in windows.
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Disk Juggler!
  5. [GiB] Spawny
    2 May 2001
    Anybody know if Clone CD has any issues?
    Some people say it does a better copy?
    Not sure if XP will spit the dummy.
  6. Kevo
    9 Sep 2001
    Should work ok but it probebly depends on your cd burner...
  7. [GiB] Spawny
    2 May 2001
    Tried to do a CD copy neither worked?
  8. Forsaken
    27 Mar 2001
    used clone CD with me 8*4*32 traxdata Writer and it worked fine
  9. Guest-16
    Guest-16 Guest
    Nero 5.5.0.4 works fine?!? its the best CDburnin prog out
  10. [GiB] Spawny
    2 May 2001
    Have you a link where I can download it.
  11. Kevo
    9 Sep 2001
    Nero? not hard :p its a "Demo" version but we all know what we do with them dont we ;)
  12. [GiB] Spawny
    2 May 2001
    Help
    Will try it when I get a moment
    CD Driver is a generic 52x Speed
    HP Usb CDR 8230e
    Got the lastest patch but when I look in device manger it show its using Microsoft Driver 5.1.2535.0
    Got through 10 CD already, on the verge of chucking it out the window. :mad:
  13. [GiB] Spawny
    2 May 2001
    Nero Burn don't work either. :mad:
    Man I'm getting really p#ssed with this.
  14. macroman
    macroman The One
    3 Sep 2001
    Try them out?:rolleyes:
  15. [GiB] Spawny
    2 May 2001
    Might buy an LG drive any comments.
    The shop say it works fine on XP?
  16. macroman
    macroman The One
    3 Sep 2001
    I wouldn't have thought it was a drive issue, but a driver/software problem.
  17. [GiB] Spawny
    2 May 2001
    Officail responce from Hp on this drive is that they will not support XP until new drivers are release in the next couple of weeks!
    Bought a new IDE one any way, not installed it yet I will update as soon as I have.
  18. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    MY Nero works just fine with Nero 5.5 and Marai 12x10x32x CD Burner
