Modding CD/DVD drives at weird angles?
Discussion in 'Modding' started by SIMSY, 9 Sep 2006.
  1. SIMSY
    SIMSY What's a Dremel?
    7 Sep 2006
    I'm in the midle of a case modding project and today when i started marking out where everything was going and how it would look,
    When i measured up the DVD drive it was to long to fit anywhere and i just saw a other project on the forum and he had put the drive directly upwards!
    Is it okay to do this and would i be able to have it at a diagnol angle facing upwards??
    thanks
  2. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    The tray has hooks on 2 sides so that they can usually be on their sides and face up (just open your drive and check it out, I'm currently using mine at on it's side and at a 45 degree angle and it works just fine, and I suspect yours will too
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    will a dvd slim work well at an angle between 25-35 degrees?
