Modding cd possition
Discussion in 'Modding' started by Zoomer, 25 Nov 2003.
  1. Zoomer
    Zoomer What's a Dremel?
    30 Jan 2003
    i'm going to be starting my latest project in the new year and need to get as much down as possible.
    is there any reason why i should stick to putting my cd drives horezontaly. It would make life easier and the design would work better if they where vertical for this case.
    eg.
    :confused:
    PS.
    do you know any good slot loading DVD and CDRW Drives
  2. ArsoN
    ArsoN What's a Dremel?
    30 Sep 2003
    You'll have to check your optical drives have the little ridges around the CD tray to hold it upright (I haven't seen one that doesn't in almost 6 years), but other than that, I can see no problem what so ever.
    As for slot loading drives, I think most people use the Pioneer A106(?), I know it's pioneer anyway. :p
  3. Nexxo
    23 Oct 2001
    A good slot loading DVD/CD-RW combo drive is the Panasonic CW-8122-BPN laptop drive (use an adapter to fit to standard IDE).
    You can buy it :here:.
    Find a review :here:.
  4. Zoomer
    30 Jan 2003
    intresting but i'm looking for somthign a bit faster then 24x reading of normal cd's
  5. Deca
    Deca What's a Dremel?
    28 Aug 2003
    the pioneer slot loading dvd drive metioned above is pretty good. i use one atm.
  6. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    Why? Seriously.. aside from 1 time copy of large files I don't see the advantage. Maybe software instllas go fractionally faster.. but can't be by much. If we were talking about a burner I'd understand it more.
  7. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    Nice, but perhaps a little too expensive.
  8. Nexxo
    23 Oct 2001
    Hey, you makes your choice and you pays your price. :D
  9. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    i was also thinking about this.
    i just got a hold of a compaq black bezel 24x cd drive ultra thin laptop for only £6 including p+p from a thinkpad w00t!
  10. [t0rc]
    [t0rc] What's a Dremel?
    28 Nov 2003
    Hands down go with the Pioneer 160s. Its superbly stable and you won't need any adapters or anything for it.
  11. Deca
    28 Aug 2003
    yeah, and its nice and easy to take apart and put back together again :D
  12. Nexxo
    23 Oct 2001
    Noisy bugger, though.
  13. Bossman
    6 Nov 2003
    Your best bet is to buy an old laptop, i was offered one for about £30, could have used the CD, Hard drive, floppy and keyboard but i couldnt be bothered doing the mod in the end.
