Gaming CellFactor: Revolution
Discussion in 'Article Discussion' started by Tim S, 13 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    it's a broken game and you gave it 6!?!?!?!
  3. capnPedro
    11 Apr 2007
    I hope to God you'll be reviewing Unreal Tournament III both with and without a PhysX card installed. I'm definitely buying UT3, but it might convince me to get a PPU as well. I would certainly get one if they were priced more around the £50 mark.
  4. Tim S
    Tim S OG
    8 Nov 2001
    We will be, don't worry about that :)
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Yea, I think a 6 is a bit too high. it's a problem I commonly see in BT reviews, there's hardly any variation. Everything gets a 6-10.
  6. Guest-16
    Guest-16 Guest
    That's because most things are average to good. We generally work with manufacturers that have got things right. In the same way read this: http://www.trustedreviews.com/editorial/2007/04/30/A-Question-of-Integrity/p1 because it explains how the industry has changed.
    If we waste our time with an equal amount of crap, you won't buy it, the people who make it don't get anything out of it other than the obvious: that it's a poor product. If something is 50% right, 5/10, then you wouldn't buy it, whereas 70% is "average" and you'd be more inclined to, but it's still average.
    EDIT: After editorial consultation and your points taken into consideration it's been dropped to a 5.
  7. Tim S
    Tim S OG
    8 Nov 2001
    I'll accept responsibility for not picking up on the connection between Joe's words and the score he gave the game. I'm burning the candle at both ends trying to get a certain graphics card reviewed in time for launch.
  8. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Though really I should accept responsibility. On reading through my notes again, it's obvious that I was giving a score out based on the promise of PPU in a game environment, not judging the game on it's own merits as I should have done. We talked over the scoring and have dropped the score by a point to bring it back into line.
    Apologies on the error :S
  9. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    Yeah, if you where rating the PPU rather than the game on a PPU then the first score might have been ok.
    Damn I can almost taste that R600 release date!
  10. Guest-18698
    Guest-18698 Guest
    14th isnt it?
    yeah that game looks crap lol flying boxes... woo
  11. Mathmarauder
    Mathmarauder What's a Dremel?
    14 Jan 2007
    Even if you rate just the game its not that great. The throwing boxes thing was only fun for a little bit, I wanted to do something more with it. What would get me to buy a ppu and this game is have a CTF mode where the forts are destructible and respawn after a while, to me that just screams fun.
    But in reality the novelty wore off pretty fast.
  12. Guest-16
    Guest-16 Guest
    Torn the cloth yet? That was the only thing that made Joe and I go "WOOooooooo". But yea, it wore off pretty quick.
  13. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    AGEIA can't really pin its hopes on UT3 since, although UE3 does incorporate support for PhysX, UT3 doesn't use it for anything game-altering. It's just eye-candy.
  14. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    did the game work any better on an 8800GTS/GTX ?
  15. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    color anyone
    I don't like the black&amber of the game, although the advantage is that you could play it on a herculus display from the 80's I guess.
  16. completemadness
    completemadness What's a Dremel?
    11 May 2007
    hmmm i thought this game was just crippling my computer (maybe due to having 2x 1680x1050 screens running) but it appears that it may partly be the games fault itself, i didn't realise it was that demanding
    By the way, is if possible to get PPU code on 1 core and the game on the other, ATM its all stuck on 1 core, but does dual core in this game make a difference ?
Tags: Add Tags
