ok heres what i'm planning to do.. i'm thinkin of hooking up a car sub to my pc system. i'm thinkin of getting this amp http://www.bestbuy.com/detail.asp?e=11217260&m=3026&cat=3015&scat=3012 it says 450 watts, can i wire a 450w computer PSU to it, since they both require 12v.
wont work the psu may supply 12 volts but its amperage wont be enough, it may jsut work but i gaurantee if it does it wont for very long the only person i know who has sucessfully used a car sub in his hifi kit is HK but he has used a propper hifi amp & a EQ to boost the frequencys slightly as car subs work but not brillaintly in the home sorry to rain on your parade mate (thought about trying it myself)
what if i use one thats made for home, i seen it somewhere before where u can buy the sub and amp for a home system.. i'm jus so tired of the base the are produced by computer speakers.. i tested out the logitech z680 and that thing still dont sastify me.. i need like a good 12 inch sub
Trust me, leave the car stuff for the car. There are plenty of prebuilt home audio subwoofers and some amazing DIY subwoofers, what kind of budget do you have. For prebuilt subs Velodyne CHT 10 and CHT 12 are good. For custom subwoofers and parts check out. http://www.acoustic-visions.com/ A full DIY subwoofer can be great, there are some excelent drivers from www.Adireaudio.com the "Shiva" from USA , if built from Adire plans (reference designs on the web site) e.g. put in 3 cubic foot vented enclsure tuned to 20hz will provide amazing bass output right down to 20 hz, this will rival subwoofers in the £500-£1000 range. If you want to check out the Shiva look here. http://www.adireaudio.com/diy_audio/drivers/adire/shiva.htm For enclosures degisns check out, http://www.adireaudio.com/tech_papers/shiva_apps.htm
Yes I believe thay are, your Location is NYC (New York City) that is why I selected them. If you have any other questions feel free to ask
thanks micb for all the help, theses sites are awsome unfortunally my budget was only 200 but luckly i asked my friend and he said he had a extra 12 inch subwoofer w/ a 80hz crossover built into it. what type of recievers do u recommend??
Good budget receivers, slightly older models are: Denon AVR 1602 and the Marantz SR 4200. The Onkyo TX-DS595 or Onkyo TX-SR600. Then Denon AVR1802 and Marantz SR 5200. Look to see if the receiver you want has Dolbly Prologic II it is well worth having on a receiver.
You can get car subs to run on hifi gear. I done it Although the 100w amp I have driving it is no where near powerful enough for what that beast can do.
My housemate runs a 15" JL Audio car sub AND a 10" Infinity car sub for his hifi in addition to KEF fronts, centre and rears. You can see from his complete spec though that he's got plenty of power from the yamaha and the rotel. Yamaha DSP-AX620 AV processor/amp Rotel RB-970BX stereo power amp KEF Cresta 2s (fronts) KEF Cresta 1s (rears) KEF Cresta C (centre) Infinity Kappa KCS100BR (sub, 1cft sealed) Sony MDS-JE520 MD Deck Pioneer DV-350 multi-region CD/DVD transport QED/Cable Talk/IXOS/Profigold cables etc It's not really a good idea to try to power a sub from a computer PSU but he was using an old 300W of mine a month or so back to power a DLS A5 - 3ch amp (designed for use in a car but he tested it on his home stuff) that he then ran his front speakers off. That amp is rated: 2 x 50RMS @ 4 ohms (typical power: 2 x 85RMS), midbass 1 x 500RMS @ 2ohms, sub and even at volume neither the amp or PSU got hot...
i got myself one of these recievers ... http://catalog2.panasonic.com/webap...pId=11135&modelNo=SA-HE75S&surfModel=SA-HE75S i got it for 150, not bad
right now, i have some crappy aiwa speakers that came with a bookshelf system, this is for temporary use. what midrange speakers do u recommend?
Axiom Audio, Paradigm, JBL S series, Ascend Acoustics, Mirage, Wharfedale, Athena, Mission and B&W. You will have to see what fits in your bugdet.
$100 that is not very much at all, what speakers do you currently own? Can you save some more money? You could buy a decent center then use you current speakers as Left and right speakers. Then save for rear speakers and upgrade the fronts to better models. Check out this site for fairly cheap speakers. http://www.htdaudio.com/ Level TWO or HTD Middies could sound ok.
