Peripherals Cheap Xinput wireless?
Discussion in 'Hardware' started by Vault-Tec, 29 Nov 2017.
  1. Vault-Tec
    30 Aug 2015
    Is there any such thing or do you really have to spend over £50?
    Yesterday I hooked up one of my dormant rigs to the TV and fancy some couch gaming.
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    There are cheaper wireless XInput controllers, but unfortunately they are junk and you'll just end up frustrated with them and buying the official XBone controller anyway.
  3. Vault-Tec
    30 Aug 2015
    Bummer. Oh well it will have to wait then.
  4. GeorgeStorm
    16 Dec 2008
    What's wrong with an xbox 360 controller?
  5. Vault-Tec
    30 Aug 2015
    Nothing except the price. To buy one wireless with the batteries etc is just so expensive. I have two, but sadly they are both wired. The PC is about 15ft away, and IIRC if I used a USB extender it started to misbehave.
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    PS3 controllers work perfectly and natively on a steam link, but a quick google says you need to manually install a driver to get them to work on Win 10 over bluetooth. They're good, reliable and cheap though!
    https://github.com/nefarius/ScpToolkit/releases
    £15(ish) new.
  7. GeorgeStorm
    16 Dec 2008
    Thought they were less than £30 when I got mine, certainly less than the £50 you quoted in the OP.
    My experience of PS3 controllers is I never got them working, but others have so could be worth looking at.
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nice find:thumb:
  10. Vault-Tec
    30 Aug 2015
    Thanks man will consider that when I have some more cash :)
