Chii-EDPC (8/20 Lil'Update)
Discussion in 'Project Logs' started by Kumo, 15 May 2005.
  1. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Where E means E-Mule/Emergency...
    I did this project just before the Darkwater to replace my old download system and to serves as file server and others. Also, was a test for the DarkWater project. It isn`t still finnished and i`m planning some stuff more.
    The system is based on a Epia M10000 and a Shuttle box. Is perfectly capable of playing DVD, divx, run Quake3 if needed and, of course, download stuff 24/7.
    I get the empty shuttle case from a local store, where was used as demo.
    The log:
    Some stuff.
    The Epia M10000
    200W PSU
    As usual, the first job is remove the front and other useless parts.
    Under the bezel... Some cuts needed
    Clean chasis
    Cutting the rear IO plate from shuttle to allow the bigger one from Epia
    To acomodate the Epia board and its IO plate, a needed to cut a PCI slot cover of the two in the case. The outer PCI slot remains useful and match with the ona in the board.
    Adapted plate
    Fixings for the board
  2. Kumo
    18 Oct 2004
    First assembly test
    Ram is too close of the PSU... But too close doesn`t mean touching :)
    Back to the front work.
    Marks for the LCD Cuts.
    And cuts in the chasis to left space for the LCD board.
    Before...
    ...After
    Replacin the original plexy bezel with a dark tinted piece.
    And the silver coloured sheet with a new one in black.
    More to come!
  3. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    Looks good so far! :)
  4. Kumo
    18 Oct 2004
    THX!! :)
  5. phantomxc
    phantomxc What's a Dremel?
    7 Dec 2004
    lookin uber sexy (scratchin primier off my hands waiting for mine to dry ^_^ )
  6. mafia11671
    mafia11671 What's a Dremel?
    7 Feb 2005
    I'm getting to where I am kinda fond of these Shuttle mods, and this one is no exception. Nice start!! :rock:
    Mafia
  7. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    Yea, another shuttle mod. I cant wait to see it done.
    Im tring to get ideas for my shuttle
  8. Kumo
    18 Oct 2004
    Today update.
    Painte plate from Sony DVD rom. Then i decided to switch for a DVDRW from LG that recived the same cosmetic job.
    testing the front. The LCD dead in a shortcircuit. So...
    ...I need a new one...
    With a new fitting test. The LCD don`t brigth too much, but its ok for me, because this time i don` want to put any on/off switch for the light or dim.
    The exhaust port.
    As i cutted the grill in the back, i need some stylish finger guard...
    Cutted grill.
    Old stripped fan. Only the frame was needed.
    Sanded, painted and instaled frame as exhaust port. Also, as you can see later, it serves as cable manager.
    Stay tunned!
  9. BrokeEnthusiast
    28 Mar 2005
    Not to bad!
  10. Kumo
    18 Oct 2004
    Thx :)
    Little update more.
    Testing the port as exhaust and cable manager.
    The fan is an Antec Red led. Not too much noisy.
    Some mesh in the open printer hole to pass througt the LCD cable
  11. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    the fascade looks great in the dark, what about adding some lighting around the edges or in the feet?
  12. Kumo
    18 Oct 2004
    Give me some time hehe :)
  13. Kumo
    18 Oct 2004
    An update more... and, of course, lighst for Phaeton.
    With a pair of theese old crippled TT fan controlers i`m gona create a "slot-bus"
    Modded PCI slot cover. The other part of the "thing".
    Assembled on position.
    Outter look. Top=High Mid=Low Bott=Low
    Sleeving, wire managing and testing:
    As you can see, in the botton there is a Red glow wire to enhance the overal look of the case.
    No light, no flash...
    More to come.
  14. Firehed
    15 Feb 2004
    Very nice work so far :D
  15. irish modder
    irish modder What's a Dremel?
    4 Mar 2005
    where do you get these key switches, and are the momentary?
  16. Kumo
    18 Oct 2004
    I get those in a Electronic parts shop. They aren`t momentary, to power ON, turn the key to ON position and return to initial position (before 4 secs XD).
  17. Kumo
    18 Oct 2004
    The last update of the part one. I have to decide how to continue or if continue it. Overall it must remain as a simple and quick mod...
    The pics:
    The handle mounting.
    Testing at home...
    ...And testing at LAN
    Real LAN proof :)
    I did theese first jobs in one intense week but i can`t measure in real hours of work. It isn`t a very "eye-candy" mod, but is usefull and quick to made. And overall is silent and the red light (and soft LCD backlight) don`t disturb me at night, so it can be "e-muling" 24/7 without problems.
    More pics on te second part... if so.
    THX for the comments.
  18. xcxz
    xcxz What's a Dremel?
    19 May 2005
    nice that frontpanel :) i always liked sff because theyr good to modding and girls like em :)
  19. Kumo
    18 Oct 2004
    Do you flirt with your sff? "Hi, i`m XCXZ and have a Shuttle! Have seen my case? has a great heatpipe waiting for your heat..." :)
  20. Rufus-Seal
    Rufus-Seal Guest
    Red color fans and a tiny pc with lcd = :hip: :cooldude: :naughty:
