CISCO Router?? need help
Discussion in 'Tech Support' started by Otis1337, 18 Oct 2008.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Can anyone expline what a CISCO Router is (not linksys home routers) or give a link to a site that does...
    Having truble finding a good source to read it up on.
    Thanks
  2. markjw
    markjw What's a Dremel?
    4 Aug 2007
    http://www.cisco.com is a good place to start - manuals for the hardware and IOS (Cisco router OS) plus a lot of info on network protocols & routing etc.
    Is there something specific you are trying to do or find out?
    Mark
  3. Otis1337
    28 Nov 2007
  4. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    cisco routers are built mainly to suit the needs of a business. The different routers that they have are all designed to meet different needs depending on what the business requires.
  5. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    roughly similar in usage to any other router, but expensive enterprise-grade versions.
    very expensive, many features and not very easy to set up :)
