Modding Clean Cutting Alu
Discussion in 'Modding' started by Forsaken, 18 Jun 2002.
  1. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    I know this must have been a fair few times, but here goes, what is the best way to make a very clean cut in a Alu case panel at home, intend to do a window but without the ugly molding :)
    If anyone knows of anyother posts you can point me there :)
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  3. Forsaken
    27 Mar 2001
    Thanks mate, im going to try and get me hands on some alu sheet from a local supplier to test stuff on before tools touch case :), just need a design to do now :)
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Be prepared for plenty of filing (so leave room when marking your cutting line), aluminium is so soft you can't avoid tool marks and burr.
    Good side is, it files up easily & beautifully :D
  5. Forsaken
    27 Mar 2001
    Thanks :), just looking up geting the cost of getting it laser cut or the like, just to check out price, but i will prob end up doing it me self
  6. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    If you are using a dremmel its very quick and painless , if u are going to use some trim u don't really need to file either :)
  7. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Once you've filed back to your finished line, get some fine grit sandpaper and got over it once more. It'll remove the filling marks, and leave you with a nice smooth edge.
  8. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
  9. banished
    banished Necromodder
    6 May 2002
    Has anyone out there used a nibbler for this kind of work? They're not great for large areas, but they will cut down on time/possible bending on hard-to-reach areas.
  10. eddie_dane
    31 Jan 2002
    I used a nibbler to do my round corners because it does such a nice clean cut but damn... couldn't use my hand for about a day... now I reserve that tool for little mods like making bezels for drives, etc...
