CPU Cleaning CPU Gold Contacts?
Discussion in 'Hardware' started by gtiboy, 11 Apr 2016.
  1. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    Hi, Can the CPU gold contacts be cleaned with alcohol without damaging the CPU?
  2. rollo
    rollo Modder
    16 May 2008
    Qtips + 90% + alcohol does the job fine. Be very careful as if you knock anything your going to break the CPU. It's not worth the risk in all but the worst cases of thermal paste stuck on it. Which I guess is what it is.
    It's a slow process and needs steady hands and a clean area.
  3. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    I think most electrical cleaning products including alcohol (not the drinking kind, of course) will be fine. It is, after all, just a ceramic/PCB base with gold contacts. As long as the solution will not leave a residue on there.
  4. David
    7 Apr 2009
    Angle grinder - after trying it once, you'll never have to clean the CPU, ever again. :p
    On a more serious note, TIM Clean or Isopropyl alcohol will do the trick.
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Isopropyl + lint-free cloth, or just Contact Cleaner. Be sparing and don't go soaking the thing, or at least if you do give it a good few days for anything trapped under the IHS to evaporate.
