Cooling Cleaning Pipes, Nice and New!
Discussion in 'Hardware' started by Murdoc, 25 Mar 2005.
  1. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Yesterday, with the help of my assistant dodge I changed the water in my loop. Took everything apart, dusting with a compressor etc.
    My pipes were filthy thanks to water wetter a horrible hard to remove gunk!
    So I tried pushing fabric through the pipe, but this did very little. Then I struck along the idea of wadding fabric down the pipe and connecting the air compressor to it, I used the pipe for the standard fittings, fits nice on my 1/2" pipe, maybe a clip for high pressure.
    So:
    1. Wad a strip of fabric (old sports socks work great!) down the pipe, use a stick of some sort to push it down.
    2. Add a little water
    3. Connect up the compressor, using a clamp to stop it shooting out.
    4. Slowly increase the PSI until the fabric moves, and cleans the pipes.
    5. Repeat
    It cleans them up so they look brand new.
    When the fabric comes out, it will come out FAST!
    Dodge was at that end :D managed to fire a bit of sock through the bag.
    Dodge has pictures on his phone but atm no way to get them off :sigh:
    Hope this comes in handy for someone.
    'doc
  2. rkenny666
    rkenny666 What's a Dremel?
    7 Sep 2004
    hmmm might have to try that, i soak them in boiling hot water for a min or so, then use the fabric/string method, works ok, still abit cloudy tho
  3. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    Aquarium tube cleaners come in a variety of sizes and work well. Especially when you use isopropyl alcohol, but make sure you let it dry very well before using it again. The best stuff is the 91% or 99% pure stuff you can obtain from the druggist.
    The ultimate solution to this ongoing mess :wallbash: is to use a UV sterilizer in your cooling loop. Then anything that starts growing is killed immediately. However, a mid-size tower would be kind of cramped. Just about any pond or aquarium store should have it, but look around for a small 5-10w unit. Some people make their own and you can get the neccessary supplies at the aquarium shop as well. :idea:
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    A UV steriliser is only good for living organisms, not the coating left by WW.
  5. Murdoc
    25 Jul 2003
    I was just about to reply with the same, not a great deal can be done to stop the WW 'stains' besides not using WW.
    'doc
  6. linger
    linger What's a Dremel?
    10 Feb 2005
    would you need an adative if you used the uv stuf?
  7. Murdoc
    25 Jul 2003
    Generally, UV dye doesn't have anything besides a dye, you really do need a corrosion inhibitor aswell.
    'doc
  8. linger
    10 Feb 2005
    thats not what i meant... i thought you were talking about those uv water cleaners (use uv light to kill bacteria), not uv dye.
  9. Murdoc
    25 Jul 2003
    Ahh as we said before, after 'Top Nurse' enlightened us with his infinite wisdom :eyebrow: , the UV sterilisers will only destroy bacteria and will not stop WW 'stains' and galvanic corrosion.
  10. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    how long did you have the setup running to get all that 'orrible crap
  11. Murdoc
    25 Jul 2003
    Not that long, its only a discolouring of the pipes, not really 'orrible crap just unwanted.
    'doc
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Way to stall on those new pics of your heatercore 'Doc :(
  13. linger
    10 Feb 2005
    thats what i was worried about
  14. Murdoc
    25 Jul 2003
  15. Leeum
    16 Feb 2004
    Sorry never noticed :blush: Apologies for the OT.
  16. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    ill try and get my bluetooth dongle back, to get the pics off.
