Modding Closet in Comp.....need ideas for it
Discussion in 'Modding' started by IhaveApacemaker, 2 Aug 2003.
  1. IhaveApacemaker
    IhaveApacemaker What's a Dremel?
    1 Aug 2003
    See i need help fast on my comp placement
  2. Ouches
    Ouches What's a Dremel?
    27 Jul 2002
    Could you possibly elaborate on what your asking a little more?
    As I understand it, you want help with how to set up your computer in your closet, because a closet in a computer is pretty out there if you ask me.
    The easiest way to set up a pc in your closet is to route cables to it, all you really need is a power extention and a network extension. Its possible to just run the 2 cables under the door to a closet or something like that. Once that is complete, setup is just like regular.
    I also dont think this is the proper forum for this thread, so mods...
  3. MilitantB0b
    MilitantB0b What's a Dremel?
    8 Jul 2003
    Dude, this is the mod guide forum, as in, if you aint guiding someone through something, it doesn't belong here.
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Moving to modding... please try to post in the right forums.
    And welcome...
  5. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    You might want to post a picture or two, elaborating on your problem?
    People here are more than happy giving advice (even if its unwanted:p ) as long as you are clear about what the problem is in the first place.
    ...and welcome to Bit-Tech.
  6. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    IF your'e asking about putting a computer in a closet, make sure it's rather spacious...
    I have a two door closet [ bout 2 doorways wide, 1 doorway deep ] and I ran an old Pentium 200mhz system in there as a file server overnight once and when I opened the closet in the morning there was an instant rush of hot, stale air in my face.
    Just be sure that you're computer case is well-vented OR your closet is well vented OR your closet is walk-in and has a lot of air in it to move
  7. kong
    kong cnc-guy
    24 Feb 2002
    Come on guys, it clearly says the closet is in the comp.
    What you wanna do is get some dolls house catalogues and buy some miniature clothes and stuff, then you'll get the closet in the comp, easy.:duh:
  8. cargocult
    cargocult Guest
    :D good one, mate.
    But you all have misunderstood what he's saying. He asks how to get a closet built into his computer, it clearly says so in the title. IhaveApacemaker, I think it is too difficult to build the closet into your computer. A full wardrobecloset would use up too much room and I honestly think it would look a bit silly. You would also have to make a custom case to make it fit. I think you will have to settle for a drawer instead. It's not as spaciuos as a full closet, but still very practical for all those bits and stuff that clutters up your computertable. Fortunately, there is plenty of room in the lower front of most generic ATX-case's to install the drawer. In fact, it might be my next project for 'Trine', my comp :D
    IhaveApacemaker, good luck modding your new drawer-pc. :dremel:
  9. ou7blaze
    ou7blaze sensational.
    5 May 2003
    ROFL - a closet IN a computer LOL...good one :clap: :hehe:
  10. Krikkit
    21 Jan 2003
    :hehe: If you really had a fat wallet, you could get 2 Li-Li PC-71's or perhaps the full-tower version of the Cheiftech case, stick them on top of each other then cut in some doors and add a rail through the middle and what've you got?
    Shirt Closet :D
  11. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    i think we should let this thread die.... hes obviously abandoned it... though if u think about his thread more simply, he is saying that he has a computer in his closet and is looking for ideas to mod it.... or something like that :sigh:
  12. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Remove closet from computer, Place on head, walk around town in your new fancy hat..
    Paint it, ad a window or just throw it gently intoa cardboard box, all would eb considered a case mod. Putting a computer in a closet is not necessarily a good idea. not enough air, unless it vents outsied or into teh room, however you will still have the noise issue...
  13. jake^the^cake
    jake^the^cake What's a Dremel?
    1 Oct 2002
    got a old 133mhz computer in the closet, it works as router so its always on and therefor i cant close the door without overheating it, so whatever u do get proper cooling or prepare to live with your closet open 24/7 :)
  14. benje
    benje Minimodder
    4 Feb 2002
    lol what a waste of a thread, and BT bandwidth :(
    this nuub obviously turns up and either doesnt speak very good english, or is just a plain noob.
    let him be and close the thread!
    for great justice!
    all your base...
  15. DeLorean5000
    DeLorean5000 What's a Dremel?
    3 May 2003
    Agreed Close this Spam hole!!!! we need a spam smiley...hint hint
