Case Mod - In Progress Commodore Pet - Raspberry Pi
Discussion in 'Project Logs' started by PET2021, 29 May 2020.
  1. PET2021
    PET2021 What's a Dremel?
    27 May 2020
    Hi,
    I've built a couple of PC systems using standard cases, but this is my first ever Case Mod. I bought a broken Commodore PET 3032 system online so that I could re-purpose the case for a RetroPie and general Raspberry Pi coding machine.
    The Commodore Pet was the first computer I ever saw/touched and I love the distinctive design. I also like how all the kit in contained in the one box - Keyboard, Monitor & CPU. I'll be continuing this by installing a trackball into the keyboard rather than having a separate mouse.
    I initially tried to fit a modern keyboard into the existing Commodore Pet keyboard cut out, but the layout was pretty awful and a lot of the keys were missing - plus I don't like numeric pads and have never used one in my life. I therefore decided to get the keyboard hole routed out so I can fit in a full keyboard (a 68% mechanical keyboard) and mouse. I've added a pic to show the current state of the case.
    The next step is to get the case spray painted (I'm going with the original white, but I might add a modern touch by using a metallic paint).
    ciaognep likes this.
  2. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Yes a Raspi build !
    Impatient to see some pictures about that !
  3. PET2021
    27 May 2020
    The case is with company that specialises in painting plastics, it should be completed by Friday and I'll paste in a photo. I don't seem able to link to photos so I'll upload the original case pic and then one showing the respray.
  4. PET2021
    27 May 2020
    Well, I can't upload a file either. :(
    Is there a rtestriction on newbies posting links or uploading files?
  5. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    Yes, upload to Imgur or the the like and link it in... Makes it easier as there's no file size or resolution restrictions :happy:
    Edit: i suggested Imgur as you can select a "thumbnail" size to make images uniform
  6. Jean R built
    Jean R built Modder
    17 Feb 2020
    I have used imgur for the gifs and Flickr for the photos, both give you various embedded links so you can post with the preview size you prefer.
    Flickr has the advantage of keeping the same quality of the photos you upload, imgur compress them.
    You can upload to Pinterest too if you have it, but it gives only direct links if my memory serves me right.
  7. Canardwc
    22 Sep 2011
    The files should be les than 500ko. Maybe that's the reason why !
  8. Cheapskate
    13 May 2007
    Also, they are having problems with the image upload system. You can probably try again later.
  9. PET2021
    27 May 2020
    Thanks Guys, I'll try again later with an imgur link and I'll check the file size too. :)
    Canardwc likes this.
