Peripherals Compaq Laptop not booting from USB
Discussion in 'Tech Support' started by TheMusician, 19 Sep 2011.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    My friend's compaq presario is set to boot from USB and has the capability to do so. I changed the boot sequence to boot from USB first, but no matter what, it says "BOOTMGR IS MISSING." I've tried different images, different USB drives, yet it refuses to boot from USB no matter what.
    Any suggestions?
  2. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    What OS image are you trying to boot? Is the image on the USB drive bootable? I know with some laptops you can press like "F12" to choose your boot device. But it sounds like USB drive is not bootable.
  3. TheMusician
    13 Jul 2009
    I'm actually trying to boot OPHCrack, a utility to remember Windows passwords. I used multiple flash drives so it's not that.
  4. Fuganater
    6 Jul 2011
    Never used it or even heard of it so I'm out of ideas.
  5. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    Are you trying to use it to recover a password?
    From a quick look at the software I don't think it creates a bootable image on USB only an iso to burn to CD.
    try http://pogostick.net/~pnh/ntpasswd/ instead.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    ophcrack is a tool, used to get passwords from the hash, possibly used by hackers, or kids trying to get past limited user restrictions, by getting an admin password, without removing it and causing suspicion.
  7. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    What size usb drive are you using? I have a pc that won't detect it as a usb if over 2gb, and it shows up in the hdd list instead and I have to move it to number one in the hard drive boot order list. It won't even show up on boot select menu... some bios are just annoying with these things. Perhaps the pc you're using has a same or similar quirk?
  8. jossi007
    jossi007 What's a Dremel?
    26 Sep 2011
    Are you sure that this program is bootable from a USB drive and not only from a CD?
  9. protomik
    protomik What's a Dremel?
    12 Jun 2016
    Thanks. it works great on Windows 10.
