Scratch Build – Complete COMPLETED - titan - Scratch Micro-ATX Build [RGB]
Discussion in 'Project Logs' started by CroyAlore, 19 Feb 2017.
  1. CroyAlore
    CroyAlore What's a Dremel?
    17 Feb 2017
    Here is the original model with no cutout's (My friend made all of these designs for me), I was thinking of leaving the front like this:
    I then decided to have the fans show so to begin with I had the front open:
    Then I added the design to the front (Final Design):
    Yeah I completely understand, I've noticed this same trend. It would nice if there were more than just the two options when it comes to building a loop, but I guess that just means we got to start coming up with creative ways of using one or even both styles in a build. And the same thing goes with the way we go about modding our cases.
    I've seen some builds do really well with the hard tubing, and some do amazing with flexible, but the problem I've seen is that sometimes the build doesn't use the style that fits it.
    I'm glad you prefer the flexible tubing in this build, it took a while for me to decide what parts of the loop would be the acrylic tubing, and what parts would stick to the flexible tubing. :thumb:
  2. Vault-Tec
    30 Aug 2015
    Yeah you definitely chose the right design :)
  3. kim
    kim hardware addict
    10 Jan 2016
    about new trends...I am generally not a fan of this rainbow RGB lighting effect, but it's the third time that I follow your thread and I must say that it looks pretty nice in your particular build, besides I love your front design grill and your case is really beautifull... also impressed by the extreme neatness of your work and pictures...:thumb:
  4. CroyAlore
    17 Feb 2017
    Thanks kim for the very kind words :thumb:
    I'm very picky about details so a scratch build was perfect for me, and I tried to ensure all the details of this build were clean and organized. I was originally going to set all the led's to white but the colors ended up working well with the case. :)
  5. Maarten/Pine
    Maarten/Pine Case modder
    10 Mar 2017
    That are some nice modding skills man! I like how you used the aluminium, really clean-looking.
  6. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    What CAD program are you using?
  7. CroyAlore
    17 Feb 2017
    Thanks Maarten/Pine, I love using aluminium its very easy to work with. :thumb:
    The models where made by a friend using SolidWorks :)
  8. CroyAlore
    17 Feb 2017
    Hey all, I got some more photos of the Led's for now until I figure out a way to mount the SSD/HDD's
    Here they are (Caution for anyone sensitive to moving colors/lights):
    Gif of the LED's
  9. CroyAlore
    17 Feb 2017
    I got a quick update, Here is some of the last components to go in the case that I just finished sleeving.
    Had to sleeve these cables and replace the red connector with a white one to match the case better.
    Internal USB Hub to help manage the aquaero components as well as the Hue+ Hub.
  10. kim
    kim hardware addict
    10 Jan 2016
    perfect sleeving...and pics:thumb:
  11. FatalSyntaxError
    FatalSyntaxError What's a Dremel?
    6 May 2016
    Looking really nice! Ever since I got my Ncase M1 I've had a thing for small and space efficient build!
    Just out of curiosity why didn't you just have the back panel be apart of the front unibody design and just bend it at the top so it comes down then screw it in place at the base like you've done already?
  12. CroyAlore
    17 Feb 2017
    Thanks kim :thumb:
    Thanks FatalSyntaxError :thumb:
    I really like efficient builds, after looking at a lot of cases I decided that the only way I would be able to get a case that is as small and efficient as I needed was to just build my own.
    I wanted the back panel to be separate from the uni-body because I like the look of a separate back panel and allowed me to use a thinner metal for it making it distinctly different than the uni-body. This also allows for easier future modifications and color changes if needed.
  13. CroyAlore
    17 Feb 2017
    Hello all, I have finally completed the project, here are the final photos:
  14. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Very clean build- super simple- love it love it
  15. CroyAlore
    17 Feb 2017
    Thanks! I'm glad you like it, I may be posted some more photos later with different color schemes. :thumb:
  16. kim
    kim hardware addict
    10 Jan 2016
    awesome, awesome, I love it....and your pics are...soooo perfect, hope to see you building again soon
  17. CroyAlore
    17 Feb 2017
    Thanks for the kind words, I am in the planning phase of the next build, which will be much smaller than this one size wise, hopefully you'll like it as much as this one :thumb:
  18. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    Beautiful! 5 out of 5 stars.
    you made something great. The RGB-table plate really brings the whole build together. Great work! :)
  19. CroyAlore
    17 Feb 2017
    Thanks Brodholm, really appreciate the kind words. :D
    Btw, cant wait to see how your build completed, great job so far you've really raised the bar:thumb:
