Hi I'm designing a case and need some components. If there are any already posted could you please give me the link. Heres the list of stuff I'm trying to find: Extended ATX motherboard tray with 10 expansion slots Toolless hdd rack/5.25" rack PSU bracket I think thats it but if theres anything else I need to design a case please post. Thanks for any help.
You could always buy a used case, or even trawl pc recyclers, etc. For about $10 or less, you'd have a case which contains everything you want, and you can have fun stripping it
you won't find a 10 slot motherboard tray unless you go to mountain mods, so best make it yourself. Finding E-ATX cases can be a sod as well,
Didn't notice the thread tag So do you want to scratch build the case irl? If so, then it's probably easier and more accurate, to just draw everything from scratch in sketchup.
Yer I'm going to build/get it built eventually. I don't really have anything to measure properly with or anything to measure thats why I was aksing (not laziness) the most important thing I need is the mobo tray because most of the rest I can find/draw. Thanks.
Just found out that my mobo uses the same holes as atx so I actually just need a wide atx tray. Anyone wanna help make my model look good? It's just the outside that needs doing and I'm not very creative so right now its just a box.
