Other Computer Wont POST
Discussion in 'Tech Support' started by andrewbarke, 17 Jun 2012.
  1. andrewbarke
    andrewbarke What's a Dremel?
    5 Aug 2010
    Good Morning All,
    Well im having a little bit of trouble with my mums computer, its an off the shelf acer aspire thats nearly 3 years old, and up until about a week ago everything was fine, then one day she went to use it and puff, nothing, it dosen't post, make any beeping noises at all, have tried swapping the memory around, removed the gpu all to no avail, all the fans spin and everything sounds healthy but its got me a bit confused, so any and all help would be much appricated!!
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    i've read that it _should_ beep if you only got the cpu set (no graphics card or ram) 'cause it'll notify you that its missing ram, if it doesn't do that it might be fried.
  3. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    That is my motherboard testing procedure too. Check that is has a speaker to beep, remove something important like the RAM, no beeps = dead motherboard
  4. improprietary
    13 May 2011
